Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Have you applied a transparency map to the eyebrows? There are some in the Freestuff: do a search for 'Newt' (the creator) and files for Mike and Vicky should show up. Basically, it's a black and white file that tells Poser to paint the texture on where the white bits are, and leave the black bits invisible-- so you get the illusion of detailed hair when all that's there is a flat plane or bumpy brows. You'll need to make sure that the transparency map is applied to all the eyebrow and eyelashes parts in the Materials editor in Poser, and that they all have a texture map assigned. As _Keep_It_Free says, you can set the 'Brows Gone' morph to 1, that'll get rid of them, but with a transparency map they can actually help.
