Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Yes it is. Set up the sketch you want to use in the sketch designer. Then, go to Animation Settings and set the frame for the size you want to render, and set Frame Rate & Frame Count both to 1. Then, click on Make Movie. Set Sequence Type to Image Files, Resolution to Full, and Quality to Current Sketch Settings. Then click ok and it will output to the format of your choice. :)
Attached Link: http://Cyber-Fyber.bbay.com/images/CF-DLfiles/SketchDesignTutorial.pdf.zip
DL my Sketch Design Tutorial. It has info on that feature as well as rendering larger size and resolution images.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hey friends, I just found out how to render a picture larger than the window in Poser 4, by going into render options. However, is it possible to render a sketch style render, larger than your image window, or is it possible to do a sketch render through render options? If so, how? Ben
