Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Thank you for the info. Unfortunately, your demo is giving me a "no url on this server" message for that mpg. I also, as a last resort had to try the frame by frame method, but, as I had to render out at a high frame rate, this proved impossible. My final method involved using individual cloaked sections for most of the curves. Still inadequate.
My piece was @ 29.97 for 28 seconds. How long is yours? ;> Seriously, it was a drag having to do it, but I couldn't find a way around it. I just checked on the link and it turns out that when I copied and pasted it, some little piece of software decided I didn't want the ".MPG" instead it put in ".mpg". Now wasn't THAT helpful?! Anyway, I changed the extention on the web-site, so try it again if you'd like.
Ok. Here is my RD nemisis. This applies to Carrara also.
Sounds simple, but it is not. Using the Freeform Modeler,
how can one animate a tube precisely through a seperate compound curved tube. This is a compound a snaking motion.
The fit must be precise. The length of the inner tube must essentially remain constant.
The turns must not get out of slither. Each section must take the place of the one that precedes it.
I have done alot of faking with passable, but not perfect results.
Typically I use a cylindrical freeform with as many sections
as there are curves. The problem is with getting the sections to advance sequentially and consistently through each curve .Ideas?
