Sat, Nov 30, 6:07 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: deformers ?
apache3d ( ) posted Sun, 20 February 2000 at 5:35 PM · edited Wed, 27 November 2024 at 12:35 AM
Attached Link: http://apache3d.ifrance.com
hi anybody can explain me why when i import a head in obj poser say "no same number of point" and i can change the head but i need to use it thanks
Kevin ( ) posted Thu, 24 February 2000 at 7:32 AM
You are trying to make a morph target? Don't export from poser. It will not work right. Import from the geometries folder and toss the body parts you don't need. When you make a morp target you cannot add or remove any vertices. You can only shift them around. In addtion the package you use must not change the order of the vertices.
matu ( ) posted Tue, 29 February 2000 at 7:38 AM
Thank you It works now!
