Can you give us an example, maybe with a screenshot. Poke through is a general problem with a lot of conforming clothing. Sometimes you have to make some parts of the body invisible-- the legs in particular in pants, also the feet in boots. Sometimes there's just no fix beyond postwork and the cloning brush and smudge tool. All conforming clothing needs to be with the character it was made for and all of them suffer with extreme poses--and that can include some simple sitting poses as extreme. If you show us what you're having probs with, I'm sure we can help, and I'm pretty sure it isn't your computer. Emily
My first take is the breasts look too low for default, like it is a custom body-- but I believe you. This is the kind of thing I've had happen a million times with custom bodies but never with default. I think you could probably get it to fit a bit better with scaling the hip areas larger, but . . . really? I'd reinstall Vicki and the clothing pack and try it again. You have a texture on the model-- did you use a Mor file for the character of the model? That could have changed the proportions. Emily
Another thing to try. Load Vicki without textures-- straight out of the box in the default positon and load and conform the catsuit to her then. If that fits, you know it's a problem with the Mat for the texture including changes to the body, if it doesn't fit, you need someone more experienced than me. What texture is it? Emily
I have some problem with all clothing i try to put on my character, the skin of the character go out of the clothing, any conforming ones... To adjust i have to change all the settings of the different part of cloth but that not run very good... Have you a little tips to correctly use the setting, or there is a problem with my computer or poser (i think is a problem with my computer but...) ?
