Sun, Dec 1, 1:33 PM CST
Subject: How do I?
LadyBea32 ( ) posted Sun, 04 August 2002 at 7:22 PM ยท edited Fri, 29 November 2024 at 9:39 AM
get rid of this annoying front peice on the dress. the little flap thing at the bottom. i want to make a lace dress that see through.
Poppi ( ) posted Sun, 04 August 2002 at 8:05 PM
okay...it looks like you did everything correctly. try turning off shadows for the thighs. sometimes, shadows on in poser can do real weird stuff to a transmap.
LadyBea32 ( ) posted Sun, 04 August 2002 at 8:06 PM
how do i do that. i truned off ground shadows though.
hauksdottir ( ) posted Sun, 04 August 2002 at 8:25 PM
Can you turn her 45 degree to either side and render her again? It looks like the darker area is almost coming up on the outsides of her legs, too, and on her shoulder straps. My suspicion is that you don't have the same settings across the board. Either a min/max/fall-off is different somewhere, or a highlight color is different somewhere, or something. I doubt if it is geometry, since the straps seem to be affected, too. Carolly
jerr3d ( ) posted Sun, 04 August 2002 at 8:35 PM
I'm not sure but that looks like the inner skirt of the dress, check the setting on that.
LadyBea32 ( ) posted Sun, 04 August 2002 at 8:54 PM
that what it is. how do i fix it to go away? here is the pic from the side veiw.
PhilC ( ) posted Sun, 04 August 2002 at 9:29 PM
The lower portion of the P4 thin strap dress is double thickness. Its as though it has an internal hem. To remove it use the grouping tool to set it to a new material and then set that material to be totally transparent.
jerr3d ( ) posted Sun, 04 August 2002 at 9:35 PM
hey LadyBea32 I dont have that dress but check vicki skirt setting use pure black and pure white
LadyBea32 ( ) posted Sun, 04 August 2002 at 9:52 PM
k on that i have object all to white and the rest on black. the min and max are 100%. so i dont get a shine off the dress itself. i well try the grouping tool. although last time i did that i lost the whole outfit :(
hogwarden ( ) posted Mon, 05 August 2002 at 3:40 AM
Repeat ad nauseum... "Don't fear the grouping tool... ...it is my friend." LOL:)
