Very nice shape and details (the boat I mean...yes really :-)) What kind of class is it? Can it use a spinaker? This reminds me that I haven't been able to sail for the last three weeks. Either no wind or thunderstorms :-(((( Marc P.S. I see the keel of the ship through the water, but I don't see the rudder?
A bit off-topic but the boat probably isn't turning at all. These kinds of boats are hardly ever sail level. The wind in the sails always pushes it sideways, and with the resistance from the keel that means the boat will always tilt away from the wind. Only smaller boats that don't have a keel, but where the crew maintains the balance should be sailed level. Also judging the position of mainsail and genua the blondes' hair should be flowing backwards. (Wind coming in from around 2 o'clock). Poser5 should make that a lot easier :-)
Jim, what are those dark stripes on the hull? It's not a texture is it? Maybe a higher shadow map size would fix that? (Might want to do that anyway for the shadow the genua throws on the mainsail. That looks kinda poserish :-)) I'm thinking about two details you might want to add to the boat: Most of such boats I see have some sort of railing at the bow. Sometimes just a short one. I think it would look very good on this one. And for shots in the late afternoon or evening, like your second render, navigations lights might give a nice touch. Something I would try with the first picture is to play with the light intensity. Set it at 150% for example. I find that that can give the impression of a very bright and sunny day with the a bright sun shining. Poser renders always give me the impression that there is a cloud in front of the sun :-) Then again, maybe that is what you intended since the shadows are also quite soft?
Those stripes are the regular problem Poser has with shadows on light colors, I should have put the shadow map size up. I might add the lights and a little bow pulpit (sp) rail, but maybe as parented props, I just realized I should add winch handles that way too! I did break down and add a spinnaker, after all, see the new thread I just started.
