Thu, Feb 27, 8:26 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 7:24 am)
Subject: Poseable Venetian Blinds
ockham ( ) posted Mon, 12 August 2002 at 11:28 AM · edited Thu, 27 February 2025 at 8:25 AM
Attached Link: http://briefcase.yahoo.com/occam24
Free! In PP2 form, which is not quite as convenient as CR2. One control to raise, another to set angle. The pull cords move properly with each setting; it's up to you to make your character's hand move with the cord. Go to the link, find the BLINDS1 folder, and download the BLINDS1.ZIP file; then unzip and place the PP2 and PNG in a subfolder within your Props library.
My python page
My ShareCG freebies
ockham ( ) posted Mon, 12 August 2002 at 11:30 AM
This animation shows the angle setting....
My python page
My ShareCG freebies
Hiram ( ) posted Mon, 12 August 2002 at 11:55 AM
Awesome! Thanks!
TrekkieGrrrl ( ) posted Mon, 12 August 2002 at 2:17 PM
This is SOOO COOOL!!!!!!
maclean ( ) posted Mon, 12 August 2002 at 3:33 PM
Very interesting, Ockham. I see you've been busy with the ERC/props thing. Looks good. Only problem is, you get crosstalk with more than 1 blind in the scene. But maybe the poser 5 fix will help. mac
ockham ( ) posted Mon, 12 August 2002 at 3:40 PM
Oops. Forgot about crosstalk. I'll read some of the material about crosstalk (by Rbtwhiz and Nerd3d) and see if any solutions will work.
My python page
My ShareCG freebies
FishNose ( ) posted Mon, 12 August 2002 at 4:17 PM
Doesn't the usual fix work, with a null in between each figure load? it means of course that one has to have a null with exactly the same parts as the blinds I suppose. Hope you get that sorted out - this is an excellent model!! :] FishNose
Pinto ( ) posted Mon, 12 August 2002 at 5:41 PM
What program are you guys using to make animated gifs like these? Are you converting a poser animation to gif format in an animation editing program or just using photoshop? Look great. Pinto
ockham ( ) posted Mon, 12 August 2002 at 6:29 PM
I run Poser to generate an animation in full-frame AVI mode; then I use PSP's Animation Shop to divide down the frame count and condense the colors down to a GIF small enough for this situation.
My python page
My ShareCG freebies
Little_Dragon ( ) posted Mon, 12 August 2002 at 6:31 PM
I don't know about the others, but I normally use JASC Animation Shop, which came bundled with Paint Shop Pro. It's also available separately. Great blinds, ockham!
Pinto ( ) posted Mon, 12 August 2002 at 6:52 PM
Thanks! Pinto
ockham ( ) posted Mon, 12 August 2002 at 10:03 PM
I've resolved the crosstalk problem in the crudest possible way: by setting up 4 separate PP2 files. The ZIP now contains all 4. If you need more than one blind in a scene, just insert BLIND1 then BLIND2 then BLIND3... as if they are completely different props. (They just happen to look the same!) And if you need even more, Copy BLIND1.PP2 to BLIND5.PP2 Use find/replace in a text-mode editor to replace all instances of Control1 with Control5 then save the new file. (Same way for further numbers.) There's nothing magic about the word "Control"; I just made sure that all the lines that need to be modified end with that set of letters, so that a single find/replace will do the job.
My python page
My ShareCG freebies
hmatienzo ( ) posted Tue, 13 August 2002 at 7:05 AM
Ah, did you remove the file? The Blinds folder is empty?
L'ultima fòrza è nella morte.
ockham ( ) posted Tue, 13 August 2002 at 10:47 AM
Well, I thought I had uploaded the new 4-pak last night. Apparently the upload failed. I did it again just now, and BLINDS.ZIP seems to be there now. Sorry about that!
My python page
My ShareCG freebies
hmatienzo ( ) posted Tue, 13 August 2002 at 12:52 PM
Wonderful! Thanks!!
bikermouse ( ) posted Wed, 14 August 2002 at 4:24 AM
I'll find a use for this, I'm sure. It seemed to download ok tonight. Thank you, - TJ
FishNose ( ) posted Wed, 14 August 2002 at 4:49 PM
Thanks, ockham! I know just exactly which Vicki is going to dig these - so the Mike living opposite can only see her when she wants him to! :o] :] FishNose
