Sat, Nov 23, 3:14 AM CST
Subject: Could someone explain what the morph putty tool does?
Darth_Wookie ( ) posted Fri, 13 September 2002 at 9:11 PM ยท edited Fri, 22 November 2024 at 10:48 PM
I am almost to the point where I will be able to afford Poser 5, a week or so from now I will be able to order it. I am curious about this Morph Putty tool. What does the tool do? Can you actually warp and change a model's face with ease? I read someone say it was individual dots..... can you pull whole areas? and is morph making easy? Thanks!
JeffH ( ) posted Fri, 13 September 2002 at 9:15 PM
The Morph Putty tool manipulates the morphs that are applied to a bodypart in combinations.
You can choose which ones it will use and lock off the others.
It won't work on a bodypart that has no morphs.
Darth_Wookie ( ) posted Fri, 13 September 2002 at 9:23 PM
So for example if I had a michael head, and I wanted to dreate a morph like lets say.... Make his forehead have ridges, would I be able to do this? or create something like a bump on someone's face or something like that?
JeffH ( ) posted Fri, 13 September 2002 at 9:50 PM
The MPT doesn't create morphs, it manipulates them. The bumpy forehead morph would have to already be on the figure. It's kinda like pushing on the figure with your finger to adjust the morphs that are already there.
Artist3D ( ) posted Sat, 14 September 2002 at 6:00 AM
Is there a way that Morph Putty can made eventually with an update,Able to make morphs buy pushing and pulling?That would be extra cool.
