Thu, Feb 27, 2:50 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: How to set eyelash transparency in Poser 5?
w-cloer ( ) posted Tue, 17 September 2002 at 10:20 PM ยท edited Thu, 27 February 2025 at 2:20 AM
Does anyone here know how to correctly set the eyelash transparency in Poser 5? I experimented with serveral different setting, but the eyelashes are alway rendered as a solid object ( see attached screen shot ). Also if anyone knows of a URL for a good tutorial for fixing the eyebrows in Poser 5, that would be appreciated.
TalmidBen ( ) posted Tue, 17 September 2002 at 10:33 PM
Well, I've been having some trouble with Reflection maps, HOWEVER, try this: use the P4 renderer, with Shader Trees turned OFF, and this may help you out. I've been able to get my Refl Maps working correctly in this setting, and should suffice until I figure out how to work in the Material Room better. Hope this helps. Ben MessianicArt.com
TalmidBen ( ) posted Tue, 17 September 2002 at 10:36 PM
From the looks of it though, it appears that you have: 1. Either your transparency turned down on the eyebrows/lashes 2. The map is not applied correctly on the eyebrows/lashes If those are not the case, try the suggestion in my first post. I don't think I've had this problem with P5, so it may not have anything to do with the P5 Renderer.
Kiera ( ) posted Tue, 17 September 2002 at 10:38 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=873651
Drag the transparency node to your lashtrans image map (2D), then set the transparency falloff to 0. That should help. I would post an image, but I am calculating a drape. =/ TalmidBen, I got P4 style reflections working in P5. See the link above. ;)
w-cloer ( ) posted Sat, 21 September 2002 at 2:08 PM
Hi..Again...I've tried..as best that I understand how to do what your suggestions...suggest..but I have not been able to render the eye lashes..(see screen save image)..please don't give up on me...I am hoping that a picture is worth 100 words...William C.
w-cloer ( ) posted Sat, 21 September 2002 at 2:14 PM
This picture may give more info..that will help me solve my problem..William C.
Boni ( ) posted Mon, 23 September 2002 at 12:20 PM
Just a quick observation. Shouldn't the backgrown be black, not white? Boni
Boni
w-cloer ( ) posted Tue, 24 September 2002 at 3:49 PM
Thank you Boni..I will try that and get back to you..William C.
squid69 ( ) posted Wed, 27 November 2002 at 1:10 AM
I had the same problem. I added a 2d map node from transparency edge and set the value to 1.00000. Squid
