Sat, Nov 30, 1:02 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Carrara Free Stuff here.
Subject: Map a model on a cone !
alliagedesign ( ) posted Tue, 01 October 2002 at 4:55 PM ยท edited Sat, 30 November 2024 at 12:03 PM
must be a stupid question but i need your help to map a model of a lamp-shade (unfoldind) on a cone.with UV map & Carrara. Do you see an other solution than throw all out of the window !!
Thanks JJ ;)
memaci ( ) posted Tue, 01 October 2002 at 5:09 PM
This may be off base but have you simply tried to wrap a tif file of the texture map in the color channel using cylinder mapping? memaci
Kixum ( ) posted Tue, 01 October 2002 at 7:08 PM
Memaci beat to the punch on this one. There are several projection types you can use. I would give those a spin before you chucked anything. Let us know how it turns out! -Kix
-Kix
wyrwulf ( ) posted Thu, 03 October 2002 at 7:20 PM
In UVMapper, select all, make a new map using cylindrical cap. You should get a map like the top map. Then select just the cone part and make a new map for that part using planar and don't split it. It should look like the bottom map. I did this with the cone in UVMapper.
alliagedesign ( ) posted Fri, 04 October 2002 at 5:23 AM
Thanks a lot, this is the solution I was searching ! JJ
alliagedesign ( ) posted Fri, 04 October 2002 at 12:07 PM
Yes,wyrwulf, but ...!!!!
wyrwulf ( ) posted Fri, 04 October 2002 at 9:25 PM
Can someone else help out here? This problem has to do with the way the OBJ is built, I think. I don't have enough experience with Carrara to be of any more help.
litst ( ) posted Sat, 05 October 2002 at 9:29 AM
Wow, this one a real brain teaser !!! I couldn't get any solution to work efficiently with UVmapping ... Though i will make some other tries . I'd be curious to know how other softs would do this ... But there is a simple solution that works in every case when you don't want any distortion : procedural shaders ! You can get some very complicated patterns this way, like on the pic i show, but if you really have to use a texture-map, then you're out :( litst
Wayfarer ( ) posted Sat, 19 October 2002 at 5:38 PM
Attached Link: http://unwrap3d.com/screenshots.html
I don't know if you're still looking or not, but I found this neat little program that does exactly what you're looking for. It takes a cone, lampshade, or whatever and unfolds it flat. No distortion, whatsoever.
alliagedesign ( ) posted Sat, 19 October 2002 at 6:09 PM
Hello Wayfarer, yes, still looking and a little deseperate ;) Thanks very much for you help, but it is on PC and i am on mac , snif snif ;( JJ
