AR if your bump map is not showing in the skin's material, you can add it at the materials editor, go to the bump map and select bitmap, then go to where you have stored select it and voilthat's all, maybe you will going to need to change the value, Max alwas use a 30 % as the default value for a bump map, play with that value and use what you like it better.
SAL9000 - Hello Dr. Chandra, Will I've dream?
I have some Problems with the Mil Dragon(full Version). I export the Scene from Poser Pro to Max, no Textures or Transmaps applied. But I can't see the Wing Membrane in Max. In Poser i can see the Membrane after rendering it, not before. So is it a Bug from DAZ, Poser or Max?
