Instead of all this agonizing over editing the pp2 file to remove the original geometry or deleting the rsr, etc why not just import your new obj file, assign textures/ref/trans maps, & save to your props library under a new name? If it's not an articulated prop that seems like the easiest & fastest method. :-)
This brings me to ask: HOW do you make props that does NOT embed the obj? I've noticed that all my freebies has the obj embedded in the pp2, even if they allstarts their "life" as an .obj that is imported into Poser. It's not that I really NEED external .obj's but I would like to know if there's a way to get them at all? I'm using Pro Pack.
The best way is to use a cr2 editing program like John Stalling's cr2Edit. You can get it at the Yahoo Poser Tech group. All you need to do is save the obj in any Geometries folder and then replace the lines in the cr2 with an external geom pointer. Under 'geomCustom' you'll find a list of all the vertices. prop propname { geomCustom { numbVerts 959 numbTVerts 959 numbTSets 5478 numbElems 1826 numbSets 5478 v -0.313875 0.465021 0.228904 v -0.313875 0.465021 0.219367 lots more lines f 933/477 958/958 959/959 } } Replace all those lines with..... prop propname { storageOffset 0 0 0 objFileGeom 0 0 :Runtime:Geometries:interiors:balcony2.obj } obviously inserting the correct names for your own prop, obj and folder. You can do it in Notepad or any text editor, but you have to be very careful with the syntax. mac
Thanks everyone. The .obj in question was actually a figure, not a prop. Deleting the old .rsr did the trick. I should have tried that before posting here.. feel like a real fool now. Because this worked I have another question.. What IS in the .rsr file and what is it for? The fact that Poser needs them and creates them if they are missing suggests it is some kind of compiled shortcut. Looking at the contents, even with a hex editor, doesn't reveal much. It's interesting that they are all about the same size. The only exception I have found is the main POSER.RSR file. If you delete that one... oops poser cannot rebuild it.
There are several different uses (variations) of the .rsr file type in Poser. Including Thumbnail pictures, Walk Designer launching, And Poser.exe buffering. The .rsr file in your Geometries folders is a re-written copy of the model (.obj file) you use in Poser. The purpose is that it rewrites the .obj file so it loads faster when you load the figure from the library. Poser began it's life when computers were very slow. That's why they did it this way. The ProPack no longer uses this technology for the geometries or thumbnail images. So you don't need to delete them any time you want to change things. ScottA
I have been trying to create UV maps for some Poser freebies that do not have them. I can create the UV map okay but after I save the new .obj file and open it up in Poser, nothing seems to have changed and it's not using my new mapping. Am I missing something somewhere? When I get home tonight I am going to try deleting the original .rsr file. That's the only other thing I can think of. Any ideas anyone?
