Did you start copying the painting this month after hearing the challenge? It should be just fine. I thought the rule was you couldn't pull work you did last year and resubmit it, not that you couldn't copy your or someone else's work. This isn't a finished work that has been sitting on your computer or something out of another bryce gallery site you posted long ago? I have a harem room in the marketplace that would be great for the challenge. Problem is I've had four months off and on to work on it. I even had the basic room done with all of the textures set before the start of the challenge. I also have a jason and the argonauts scene with a temple built, skeletons and warriors posed etc. Add to this a greek Trireme pulled into bryce and textured I could drop into the scene. I could pull of a fantasy scene in about a day using parts from other work. Using these bits and elements would give me a big leg up. I also don't post finished scenes. I don't use them because I see them as the non-original work implied in the rules.
Hey, I must have misunderstood. If you want to recreate a painting in Bryce, that does sound like a good idea. I agree that you can learn by recreating what others do. So if were thinking about doing something like Nuski, go for it. I learned more about free figure drawing in one session than I did all year long when I sat behind my sister and drew what she drew (instead of struggling with where to start, etc.)
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=960550
Check this one out. Beautiful example of turning a painting into a Poser render.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I've always wanted to turn this painting on my wall into a Bryce render and it definitely fits this month's challenge. Is this acceptable or does the entry have to be an original design?
