Sun, Dec 1, 2:08 PM CST
Subject: Monthly Challenge Question
Hepcatbrandon ( ) posted Thu, 14 November 2002 at 10:03 PM · edited Fri, 29 November 2024 at 10:39 AM
I've always wanted to turn this painting on my wall into a Bryce render and it definitely fits this month's challenge. Is this acceptable or does the entry have to be an original design?
EricofSD ( ) posted Thu, 14 November 2002 at 10:29 PM
One of the goals with the challenge is to build our skills with Bryce. Beginner or pro, we all have much to learn. I bet you'd learn more by making an original design. In direct answer to your question, you can read the Monthly Challenge Rules link just under the forum logo.
EricofSD ( ) posted Thu, 14 November 2002 at 10:31 PM
Hmmm, I think the voting rules have changed a bit.
humorix ( ) posted Fri, 15 November 2002 at 12:17 AM
Well I remember Aldaron did a bryce rendition of a painting by Tim Hildebrandt. So I guess you are definitely allowed to redo a painting in Bryce. However please do check the rules of the challenges all the same.
mboncher ( ) posted Fri, 15 November 2002 at 2:05 AM
Yah, the rules have changed a bit... I think AgentSmith needs to update them a touch. :c)
catlin_mc ( ) posted Fri, 15 November 2002 at 7:59 AM
Well isn't it a challenge in itself to construct a copy of a painting in Bryce. It's not just the idea that's important but the technics used in putting the image together. I think it should be allowed.
Aldaron ( ) posted Fri, 15 November 2002 at 8:07 AM
Yes you do learn a lot in recreating a painting. Trying to get the same lighting color, etc. is a great learning experience in working with lights an materials. On that note I really need to work on original material rather than other's work. :)
tuttle ( ) posted Fri, 15 November 2002 at 9:37 AM
Submit what you want, it's only a bit of fun. As long as the render's yours, I can't see anyone would be bothered.
nuski ( ) posted Fri, 15 November 2002 at 10:55 AM
Now that you brought up the subject . . . . my entry this month is an upgrade from a painting I completed in 1991. The difference. . . . my original painting took two months to complete . . . . . my entry image . . . several evenings of work. I have been contemplating creating my roughs in Bryce and then painting them onto canvas.
electroglyph ( ) posted Fri, 15 November 2002 at 2:37 PM
Did you start copying the painting this month after hearing the challenge? It should be just fine. I thought the rule was you couldn't pull work you did last year and resubmit it, not that you couldn't copy your or someone else's work. This isn't a finished work that has been sitting on your computer or something out of another bryce gallery site you posted long ago? I have a harem room in the marketplace that would be great for the challenge. Problem is I've had four months off and on to work on it. I even had the basic room done with all of the textures set before the start of the challenge. I also have a jason and the argonauts scene with a temple built, skeletons and warriors posed etc. Add to this a greek Trireme pulled into bryce and textured I could drop into the scene. I could pull of a fantasy scene in about a day using parts from other work. Using these bits and elements would give me a big leg up. I also don't post finished scenes. I don't use them because I see them as the non-original work implied in the rules.
Hepcatbrandon ( ) posted Fri, 15 November 2002 at 5:46 PM
Nothing in the rules mentioned using another's design but I thought I'd ask anyway. And no, I haven't started anything yet. I was planning on doing it anyway so we'll see if I finish by the end of the challenge. Thanks for the input.
EricofSD ( ) posted Fri, 15 November 2002 at 11:39 PM
Hey, I must have misunderstood. If you want to recreate a painting in Bryce, that does sound like a good idea. I agree that you can learn by recreating what others do. So if were thinking about doing something like Nuski, go for it. I learned more about free figure drawing in one session than I did all year long when I sat behind my sister and drew what she drew (instead of struggling with where to start, etc.)
EricofSD ( ) posted Sat, 16 November 2002 at 9:11 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=960550
Check this one out. Beautiful example of turning a painting into a Poser render.
