Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Problem solved. I thought I was loosing it there for a second. Vue was insisting my scene I guess was moving across the screen at 1000 miles a hour or somthing. That was motion blur it was rendering. This scene I'm doing has no motion but since there don't seem to be a effective way to turn it all off it insists it's moving. We need a button NOT ANIMATED ! that we can click once and vue stops asking about it forever ! I seleced ever object here and told it it's not animated nothing is animated. I've got the time set to 0 but it still asks ever time this texture can be animated you know? Do you want to animate it? NO I DON"T WANT ANIMATION!!!!! This is the problem it just like never forgets if you happen to click on something or import something that has animation. Once it's turned on you can't seem to get it to turn off.
This sort of thing happens to me all the time. Scenes will mysteriously become animated. I just go to the timeline and select "destroy object animation" and then save again and it usually solves it. I dont know where the animation comes from, but it usually happens to me when i have done a lot of booleans and grouping.(seems that way anyways). I sent a email to e-on a long time ago about this but got no response.
Where do you find the "destroy object animation" command? Which menu? I've never found that; sure would come in handy!
Oh took me a while to find it too. Click the display part on the top of the screen there then the last one click display time line then right click on the time line that's diplayed and pick from that new menu. I guess I'm not the only one that's having this unwanted animation stuff showing up after all.
Guitta the problem with changing it from standard to Not Animated is that sure it works but as soon as you move it or tweek the texture it becomes animated again. Oh I tried render to screen also. I tried everything I thought it was a bug. I got a bigger picture here rendered to screen showing the same thing. I seleceted all objects on the right then in the timeline distroyed the animation. and saved the scene again. That seems to have worked perfect.
Well I don't any more and that's good. See it's great if you want animation but when you don't want it looked to me that there was no way to turn it off. What the probem here is my scenes are huge monsters. This one was animated at one time but now I've redone the scene for a diffent project and I couldn't turn it off. I don't need the feature now on this one. It may not make much sence at first but It's easier and faster for me to just tweek and old scene to what the customer now wants than to build everything over again from scratch on a new file so that's why I was doing it this way. Some of these files I got here took years to create and tweek and have been rendered several times already. That way the new work fits the theme of the old work so they match. At least now I know how to turn it all off so for me problem solved. I can get back to work now.
