228 threads found!
Tucan-Tiki | 10 | 331 | ||
Tucan-Tiki | 29 | 397 | ||
Tucan-Tiki | 10 | 115 | ||
Tucan-Tiki | 19 | 602 | ||
Advisories: profanity
Tucan-Tiki | 11 | 197 | |
Tucan-Tiki | 6 | 175 | ||
Tucan-Tiki | 50 | 642 | ||
Tucan-Tiki | 2 | 84 | ||
Tucan-Tiki | 45 | 1262 | ||
Tucan-Tiki | 1 | 117 | ||
Tucan-Tiki | 2 | 60 | ||
Tucan-Tiki | 0 | 53 |
(none)
Tucan-Tiki | 26 | 442 | ||
Tucan-Tiki | 12 | 160 | ||
Tucan-Tiki | 21 | 381 |
1,265 comments found!
Oh you need to go to 3d warehouse sign up for the sketch up moxels download site it's free there should be quite a few star trek bridges and props there.
Thread: Where can I find a Star Trek Bridge model? | Forum: Poser - OFFICIAL
You can downloadย sketchip it's free for fully working for 30 days then download the bridges and convert them in sketching to obj and import them into daz or poser as obj.
Thread: face transfer and error | Forum: DAZ|Studio
Thread: Lost sleestack head mesh. | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Basically all you need to do is smooth out the muscle from the human figure you use so there's no sign of muscle in the legs and arms make the joints thicker the body and limbs flatter with allot less muscle curvature once you do that you will have either make hands and feet or take the figure into Z-Brush and resculpt it there with hands and feet for a much better result.
You can can fix the sleestack head with the shoulders by using the grouping tool to block out the shoulders to make tranz-map to hide all that, then make a lizard collier from a flat round circle you can sculpt it to fit with the morph brush then tranz map then edges and add a scale texture to the lizard frill which will help hide the some issues with head replacement.
You can convert these with the free spin3d program it's a free 3d format translator that can convert the sto files to obj then just do a head replacement or patent the obj to a figure you morphed with the morph brush, I recommend you use map maker to create a texture template to make a texture these models don't have any textures.
I used photos to create textures for Michial 4 still working on the figures I have to create hand claws and feet still.
Thread: Just don't save with attachments | Forum: Poser - OFFICIAL
Either that or someone write a python script or something that solves all this corruption crap.
Suprised no one has just done this already dson is extremely unstable and seems to act more like a virus corrupting the figures....
Thread: Has your Poser stopped working? License issues? Can't start Poser? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
It's definitely not the runtimes from other versions of poser mines doing the same thing with a new runtime and no early runtimes added installed all content fresh.
grosporina posted at 7:49AM Fri, 12 March 2021 - #4413639
Appears the work around is not to save the figure again with any hair props or clothing apparently dson does not except it and corrupts the figure in some way.
Basically you have to dress the figure from scratch and can't save it as a pz3 or cr2 for the the problem to go away, however I'm still getting crashes whenever I delete anything dson in the scene so if I have to remove anything I have to make it transparent to hide it because hide doesn't seem to work either.
Same issue crashes when I delete a dson figure running poser 11 on 16 gigs of memory on an I 7 quad-core with invidia 128 video memory.
Not only that but my figures after being saved as pz3 load back with corrupted fittings to clothing sometimes the figures get corrupted and spagettified stretched out in a spiral formation.
I don't know if this is the right thread but it seems like a "Poser 11 won't start or won't keep running issue" so here goes... Poser 11 will crash when I either File->Close or File->New if I have previously loaded a figure or scene that uses the DSON importer. I'm running Windows 10 and looking in my application logs I can see a new entry for every time it happens, the "friendly view" information for each event looks like this Poser.exe 11.3.818.0 5edcd5a1 python27.dll 2.7.17150.1013 5e815992 c000041d 0000000000119a32 338 01d709d4605ab9fa C:Program FilesPoser SoftwarePoser 11Poser.exe C:Program FilesPoser SoftwarePoser 11python27.dll 9e2f0a95-7374-4d4f-93ca-60e6b49310e3
It also randomly happens if I have a scene with DSON imported figures and delete one or more figures from the scene, but the file->Close and file->New behaviour is consistently repeatable. It doesn't happen if I haven't loaded any figures in that use the DSON importer. Is there a known issue with DSON and Poser 11.3 and any known workaround? I use Genesis 1 figures a lot, so for the time being I'm stuck working in Poser 10 then loading up nearly completed scenes in Poser 11 just when I want to use any new functionality like the new render engine.
I just upgraded from Poser 10 to Poser 11.3.818. Installed fresh from that version, I didn't update from any earlier version like 11.2, then I downloaded the x64 windows DSON importer from DAZ and installed it to my Poser 11 directory and loaded up all my runtimes from previous Poser versions (I have several runtimes worth of content from Poser 4 onward).
Thread: This is the death of Poser, if they never support DSON imorter | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I'm perfectly happy with 11 not going to buy 12 if they are going to keep playing war games with Daz3D
Thread: Upgrading from Poser Debut to Poser 11 or Poser 12? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Depends if you want to use Genesis in Poser I'm not sure if what I read on Facebook is true or not but I read poser 12 does not support genesis 3 or 8 and that there was enough for me to say I'm not getting Poser 12 or any future upgrades if that's how they are going to handle things.
Example of what you can do with Genesis 8 in Poser 11 and how it renders
Thread: Legacy content figures are black, and textureless | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Had this issue myself with Genesis 8 figures not only did mine turn black but they got spagettified like I had black hole lurking somewhere in the scene, I couldn't figure it out in Poser 11 so I did a new install and that fixed it
I'm surprised your having any trouble with legacy content that's weird.
Thread: Finished a Character I started last summer. | Forum: DAZ|Studio
What the Character looked like last summer.
After adding more morphs and carefully working on it here and there I finally took it from this to what you see in the above image having ironed out all the issues I had with it. .
Thread: Jason Momoa as Marvel's Kazar. | Forum: DAZ|Studio
Phone apps used were cartoon photo and photo layers to do this
The original character by Marvel
