1 threads found!
Posted Jul 19, 2016 at 8:49 am | Forum: Community Center |
3photog | 8 | 312 |
3 comments found!
CHF73, my comment above was posted a year ago and no one responded. I gave up trying to use Genesis 8 figures with expressions. For expressions, I use Genesis 3; otherwise, I use Genesis 8.
Knyghtmare2021, I am not sure what PDF you are referring to, but thanks to Wildial's instructions elsewhere in this forum, using the DSON importer and the Genesis 3 Poser Updater he created ( also available from Wildial) converting any Genesis 3 figure works great. Without seeing what you have done, my guess from your description is that the rigging has not been converted from General Weight to TriX Weight in Daz Studio before importing to Poser Pro.
Thread: Genesis 8 in Poser 11 | Forum: Poser - OFFICIAL
I purchased V8 when it came out. I was disappointed in the expressions, and I thought I saw a comment by Willdial that said the Poser Updater was not needed with V8. I had also tried the Poser Updater and received an error message (object reference not set to an instance of an object) so assumed that was that. Now I see some are using the Poser Updater successfully. I have used the same process I used successfully in converting V3/M3, and everything works fine except the expressions, specifically the bottom half of the mouth. I use DSON sub D 2. I use the old version of DSON Importer, as recommended in this Forum. Should I have converted to the latest version of DSON Importer?
Thread: Poser 11/Poser 11 Pro: Bug Reports | Forum: Poser - OFFICIAL
I am sorry I upgraded to Poser Pro 11 so soon. I can't tell you what problems I might have because I can't get the Library to load more than one or two items before it shows no content. I think I have discovered that if I load one or two content items and save the file, usually I can reopen it and add one or two more items. Not very helpful. Between Windows 10 problems (finally solved) and Poser problems, my image making has been seriously curtailed.
