We couldn't find any threads matching the specified search criteria.
2 comments found!
Yes there is a solution if libraries has gone in P10 , due adobe flash stopage. I have W10/pc and Poser10. Solution: Exit Poser if it's running.
Find your poser.ini - the path may differ for you - mine is in
c:/Users/++user name++/AppData/Roaming/Poser/10
In your poser.ini look for
LIBRARY_EMBEDDED_TYPE 0
and change the 0 to a 1.
-Save the poser.ini file. -Relaunch Poser 10. Your libraries will come back again. A little bit different in view, but they are back!
Thread: NO MORE FLASH!!!!!! | Forum: Poser - OFFICIAL
**Thank you so much. Problem solved as per your help below. My system is Win10, pc, Poser 10. **
bagginsbill posted at 12:41PM Wed, 13 January 2021 - #4184370
OK I think I found the setting - it was introduced in Poser 10 and then rescinded - probably because it doesn't work right somehow.
c:/Users//AppData/Roaming/Poser Pro/10
In your poser.ini look forĀ
In Poser 10, this is (I think) all you would do. For Pro 2014, you'd need to choose the embedded library as well with this line:
LIBRARY_IS_AIR 0
Thread: Opened Poser 10 today... libraries replaced by a flashplayer icon. | Forum: Poser - OFFICIAL
