14 threads found!
Albertosaurus | 1 | 9 | ||
Albertosaurus | 3 | 15 | ||
Albertosaurus | 5 | 22 | ||
Albertosaurus | 18 | 108 |
2000 Feb 01 8:48 AM
Albertosaurus | 2 | 757 | ||
Albertosaurus | 13 | 73 | ||
Albertosaurus | 9 | 78 | ||
Albertosaurus | 1 | 7 | ||
Albertosaurus | 5 | 32 | ||
Albertosaurus | 7 | 39 |
1999 Dec 13 10:53 PM
Albertosaurus | 5 | 15 |
1999 Dec 12 4:02 PM
Albertosaurus | 6 | 27 | ||
Albertosaurus | 5 | 60 |
64 comments found!
Thread: Prifered state problems with version 4.03 does any one know how to fix it? | Forum: Poser - OFFICIAL
There appears to be a bug in which if poser starts in the default directory set up by the patch (most likely windows or winnt), it is unable to find the prefs file.
Try this. Open the shortcut in your control panel and alter it so poser starts in your poser4 directory.
Thread: Anybody know where I can get a flashlight model? | Forum: Poser - OFFICIAL
Thread: Connection Machine high-multi-parallel clip-on coprocessor | Forum: Poser - OFFICIAL
Baewolf is a scheme to cluster multiple Linux machines into a supercomputer. There should be links to info on Baewulf from www.kernel.org or www.slashdot.org
Thread: Maier's DL's | Forum: Poser - OFFICIAL
Thread: Amd or Intel?? | Forum: Poser - OFFICIAL
Max 3.1 runs under Win 2K without a glitch. Darkness: You need to decide if you need two processors or one. If two, then you have to go with the Intel platform. However, I strenously advise against the 820/840 chipsets. If money is not a problem, I'd recomend something with ServerSetIII chipset. If money is a concern and you want a single cpu, then wait until socketed Athlons come out with on-die cache, which should take place in about two weeks if AMD doesn't delay.
OK, here's the deal. If you need something now, get a coppermine. If you can afford to wait a few weeks, get something with a socketed Athlon. Under no circumstances should you buy a slotted Athlon at this point in time.
Thread: Razor! work in progress | Forum: Poser - OFFICIAL
I think you need more detail on the joints, and the feet need to be a bit bigger to provide a more stable support platform for the body.
Thread: Good News for Mac OS X | Forum: Poser - OFFICIAL
Instead of his SGI's? I highly doubt it. Given it's current hardware the Mac is a mediocre graphics workstation.
Thread: <b>Virus Update</b> PLEASE READ! | Forum: Poser - OFFICIAL
Yes, Gnome is a windows manager for Linux and other Unixes. Now, since there seems to be a general demand for a short consise guide to making Windows safe from these kinds of parasitical attacks, I have here a short guide on securing Windoze. 1. Remove your installation of Windows 9X. 2. Install Windows NT4.0/2000, and make sure you use the ntfs file system throughout. You are now immune from most boot sector viruses such as Chernobyl. 3. Create yourself a user account which you will use. Do NOT make that account an administrator account. Configure the policies of your computer to give this account the minimum amount of priviledges that you can get away with. In NT4 this is done via the User Manager in Administrative Tools. In Win2K you have to use the MMC.
Thread: Anyone know how to get a obj file from a 3dsmax file? | Forum: Poser - OFFICIAL
If you turn on non-linear history in photoshop, you pretty much get the same effect. Construction trees are not uncommon in high-end design packages. The thing with Max is that because of the awesomely powerfull plugin API, quite often two Max users might as well be using two different programs.
Thread: One more redundant question (Poser update) | Forum: Poser - OFFICIAL
