1 threads found!
Posted Mar 06, 2009 at 12:11 pm | Forum: Freestuff |
AuntX | 14 | 342 |
6 comments found!
Do you mean trace the pattern in Illustrator? I have Illustrator CS 4 -- I seem to recall there's a way to create outlines from bitmaps?
Thread: Anyone know where this texture can be located? | Forum: Freestuff
Beautiful! Thanks -- were these digital fabrics (for purchase), or actual fabrics? If they were digital, I'd purchase them and use them.
I you look at the attached file / pattern from the Silverleif Studios texture pack, I think even the individual elements are different.
Part of the problem with using it as a repeat pattern is that the V4 jeans are much higher resolution, and if I try to map that pattern then it comes out very tiny. I've tried resizing it larger, but it loses its resolution.
I guess one possibility is to re-create the elements individually in photoshop, then apply them as a brush onto a new piece of denim.
OR -- I could use the clothing conversion tools, like CrossDresser, to convert it from an original V3 pant to use with V4, then try to apply similar morphs as the V4 jeans.
The original artist did this package a while ago -- so it's entirely possible she wouldn't be able to recall exactly what she did.
3DZ,
I have that SIlverleif Studios texture pack, and you're right -- it's similar -- but not the same one.
Acadia,
I've been in touch with Cimerone. She's the one who can't recall where the fabric came from, except that she was pretty sure she found it here on Renderosity.
