1 threads found!
Posted Jul 24, 2006 at 10:27 am | Forum: Carrara |
Azeiku | 4 | 195 |
5 comments found!
Thanks for your help. It didn't directly help me but indirectly it'll make my renders look a ton better! Thanks a bunch!
As for the problem I was having... I was playing around with it last night and finally figured it out. There is a setting in the Anything Glow properties for the offset height or something like that. I'm not on my computer with Carrara on it so I can't look it up. It's at the bottom of the list of stuff and there is also a minimum height or something like that too. Both are set to 0.25 inches as default and that was too high for me. I had to shrink it to 0 inches and then I no longer have the issue! Yahoo!!
Here's a screen shot of my room without the issue. This is just a start.. no textures exist yet in my scene.. I wanted to verify that I could get the lighting that I wanted before I took the time to texture things.
Thanks again!
Azeiku
Thread: Problem with Anything Glows... Please Help! | Forum: Carrara
Thanks, for your reply. The Fire Tray thing that I setting to glow and putting the Anything Glows (AG) on is a seperate item in the scene than the ceiling and wall. But they do touch. I've been welding them all together again to move them.. then right before I export from Hex2 to .obj to get it into Carrara I extract those faces. Is this the wrong way to do it?
I'm going to test increasing the lighting accuracy and object accuracy. I have no clue where to do it but I'm looking now!! ;-)
Thanks!
Azeiku
Thread: Carrara Studio 2.1 free | Forum: Carrara
I did find a not too bad of a deal on this site for Carrara 4 Standard. $94.95
http://store.purplus.net/eoca4st.html
Now, if I wanted to upgrade, do I have to go from 4 to 5? Or could I go from 3 to 5? Or even 2.1 to 5.1?
Thanks,
Azeiku
So, I have to be a subscriber or something to get the copy? Is there somewhere I can download it? I have never used Carrara before. Is 2.1 worth the energy? I know this is somewhat a stupid question but what does 5 have that 2.1 doesn't... I mean, is there some place I can look up what has been added from 2.1 to 5.1?
Thanks!
Azeiku
Thread: The Wedding | Forum: Photography
