1 threads found!
1 reply with content advisory
Backfire2024 | 43 | 3303 |
6 comments found!
Reinstalling an older flash version should actually work, it worked for me on all machines. Win Updates do not remove it no Time machine needed , as alternative you can also use " Adobe AIR, with settings to external Library ".
Thread: Library Trouble | Forum: Poser 12
You seem to run a alternative Library version, I do not recall the name.
Resetting the Library try removing the folder C:\Users\Sample\AppData\Roaming\Poser Pro\10
Make a search in the Internet for Adobe Flash archives and find
"install_flash_player_11_active_x_64bit_11.2.202.235.exe" or bellow
These do not have the kill switch and will work with your local applications. best is to use the 11.2.202.235 version. after install all your older Poser versions will work just as supposed to.
Thread: Victoria 4 Breast Morphs | Forum: Poser - OFFICIAL
Perfect V4 does not seem to have any R-nipple and L-nipple, These can be found officially in the V4 Weight map edition ( LeftBreast, RightBreast ) or the SASHA-16 versions ( Right Nipple, Left Nipple, RightBreast, LeftBreast, Breast Deformers - ignore / collapse ) or some less known alternative V4 versions.Y-phil, I've loaded the PerfectV4 Complete Supermorph preload, the 'Inject All Fixes' and I've loaded all of the .py scripts via the 'Inj Script' but how were you able to get the Nipple Conformer, R-nipple and L-nipple under the Chest to show up in the Hierarchy editor?
Thread: DAZ censorship | Forum: DAZ|Studio
Renderosity should think a little ahead! Forum Censuring causing complete bans Inclusive the customers purchases and access to legal acquired products and licenses from vendors even acquired activation licenses of software
reallusion had the same issues back in 2017 and had to take a quick action to fix that issue after some legal confrontations.
Forum-Clarification Quote !
Daz is using the same mechanisem to protect the Customers rights just like Reallusion, Renderosity as a unique exception does not give any respect to there customer rights. If they do not like what you say in there forums, they will abuse the situation to steal all customer Investments with compete bans of purchased products.
Another thing to what censuring is leading
"Printed in case of removal"
Censorship just backfires on the ones who do. Forums Die out of fear because customers fear loosing there accounts. Members find other places where they can place there honest opinions and they sure rant, these honest members and customers end up in Warrez forums without censorship. That is what it is causing and sure is not productive as these start sharing and ranting really badly.
Things like this
The net is starting to get full of ranting about Poser and DS , you do not even want to know what gets posted on Warrez! The main issue of this censuring is that good customers end up on the other side . So ask your self who is the cause of a great damage.
People can't be controlled with censure
