2 threads found!
Balandar | 26 | 538 | ||
Balandar | 3 | 83 |
8 comments found!
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=695667
Thanks for the help! This is what I ended up with.Thread: Omni Lights. Is it possible? | Forum: Poser - OFFICIAL
The max I can enter for the Angle start and End is 160. Is that what you had in mind? Or is there another way to modify the light's angle start and end?
It looks like ockham has a lightball python script. http://www.renderosity.com/freestuff.ez?Topsectionid=0&Form.SortOrder=UserName&Start=1&Form.Contrib=ockham I'll also try the two 180 degree spot lights. It takes too long to render 18 some spot lights :)
Thread: photographing monitor/tv | Forum: Photoshop
Yeah, those horizontal bands are annoying. I am not sure if this will help, but what happens is if you are shooting the tv with a fast shutter speed, you are not getting a full scan of the TV image. You'll need to slow the shutter speed down. I am not sure why they would be light or dark...
Thread: Incorporating objects into (back)grounds question | Forum: Photoshop
I'll have to give that a try. I suppose since it's close to spring here... I could take a few pics of leaves in the positions I want them in. :) Or figure out how to use brushes. How about shadows? Airbrush and opacity? Or should I use the burn tool?
