We couldn't find any threads matching the specified search criteria.
2 comments found!
Thread: Genesis 8 in Poser 11 | Forum: Poser - OFFICIAL
3photog posted at 8:56AM Tue, 11 September 2018 - #4314296
I purchased V8 when it came out. I was disappointed in the expressions, and I thought I saw a comment by Willdial that said the Poser Updater was not needed with V8. I had also tried the Poser Updater and received an error message (object reference not set to an instance of an object) so assumed that was that. Now I see some are using the Poser Updater successfully. I have used the same process I used successfully in converting V3/M3, and everything works fine except the expressions, specifically the bottom half of the mouth. I use DSON sub D 2. I use the old version of DSON Importer, as recommended in this Forum. Should I have converted to the latest version of DSON Importer?
I'm having the same issue. The expressions don't work. The mouth expecially goes banana when I try to use any expression dial. I used the latest DSON importer tho...might that be the problem? I must specify that I?m trying to import Genesis 8 Male into Poser, not the Female although I don't see why it should make any difference.
Thread: Easier way to fit conforming clothes to heavily morphed figure? | Forum: Poser - OFFICIAL
