1 threads found!
Chaosphoto | 14 | 194 |
12 comments found!
Thread: Last Week in the Gallery #39 | Forum: Photography
Thread: Poser 9 renders failing | Forum: Poser - OFFICIAL
Quote - Rendering to a separate process should help ;). I know I can never render unless I do that (and I have even less ram than you do). However, your renders, by their size, are still going to take a very long time ;). I do think that may be your main problem tho. Good luck!
Had a look in my general prefs and now I remember finding that Render in a seperate process thingy a few weeks back and changing to it just because it looked like a good idea. So thanks for that as because it is good to know I did one thing right :). Â
Â
Martin
Well, thanks Vilters. I just ran a full render at 3700 pixels and the long end and 300dpi using your suggestions and it went all the way to the end.Â
As for my lights, well I'm a photographer more than a 3D artist and so using lots of lights mixing angles and colours is just something I like doing.
Quote - Have you set the rendering to "Separate Process" in your preferences?
ah, there is just so much I don't know !!!. I'll look when this current render attempt finishes so thanks for that :)
Quote - Poser9 is 32 bit, and you do not say what OS you are running.
I think you are boucing in the 2GB Memory limiter.
Monitor your Memory consumption during the renders.
What bucket size?
Reduce bucket size to 16 or 8 or 4 to get the renders to finish.
And set MSR to 1.And is texture catching enabled in General preferences? => Enable it.
And set all textures to quality or crisp. (Crisp is better.)And??? What lights, and how many??????
Hmm, not sure what the 2gig memory limiter is. I am using Windows 8 professional 64 bit and Poser 9. I know P9 is 32 bit and have considered Pro to get past that but can't really justify the cost of it for my uses and experience level.
As for what lights, not sure which ones now but I think it is a DM set and there are 5 that I have tweaked a bit.
I'm about to have another go at it using your settings from the next message so thanks for those :)
Quote - http://www.alienskin.com/blowup/index.aspx
This is what I use...I print my graphics 13x19 and no disortion at all.. Only works as plugin with Adobe Photoshop though.
Thanks Vitachick. I have a couple of high end enlarging programs but it is much better to produce the original as a large on if I can so I'll kick poser a bit more before I have to resort to one of those.
Quote - Your render settings are too high. Post a screen shot of your render settings.
Thanks for that but my render setting definitely are high because I want a large printable render so it has to be high quality as it is for a glossy magazine.
I have no troubles rendering lower qualities or high qualities at lower sizes. I don't really understand what all the different settings do so I was using the automatic settings set to "final". There is one step above that and I would like even more to be able to use that one.Â
So really I am trying to find out what could be stopping it because I really want to use the high settings. Maybe it is one particular setting like the bucket one or maybe it is my laptop that only has 8 gigs of RAM or perhaps it is related to a windows setting I can change.Â
Thread: Photography Forum Challenge - April 2010 "Less is More" | Forum: Photography
Thread: 2010 Last Week in the Gallery 17 | Forum: Photography
Well I'll be darned, it's an honour to be selected to appear in such wonderful company.
Thankyou very much :)
Thread: Last Week In The Gallery 17 | Forum: Photography
Thanks to GiMi53 for pointing out I was in the LWIG as I didn't even know it existed and thanks also to whoever picked me, I'm truly honoured :)
Martin
Thread: Gallery Spotlight Contest | Forum: Community Center
