13 threads found!
Christian22179 | 1 | 119 | ||
Christian22179 | 9 | 194 | ||
Christian22179 | 0 | 99 |
(none)
Christian22179 | 1 | 82 | ||
Christian22179 | 8 | 275 | ||
Christian22179 | 7 | 275 | ||
Christian22179 | 4 | 108 | ||
Christian22179 | 7 | 477 | ||
Christian22179 | 3 | 107 | ||
Christian22179 | 5 | 85 | ||
Christian22179 | 6 | 103 | ||
Christian22179 | 3 | 1131 | ||
Christian22179 | 9 | 316 |
34 comments found!
Quote - I have to wonder why?
I've done quite a few side by side base tests of genesis and G2F, and G2F just works better in poses with less clothing issues; like shoes. If I hadn't have fallen in to the big intro sales for genesis; and had just bought most all the morphs for genesis, I'd have had that to spend on G2F when she came out.
Like a fool I actaully thought DAZ would do an update or two to genesis before the next figure came out. Seems I always screw up giving DAZ the benefit of a doubt.
I've seen many comparisons between the two and what improvements there are is barely a step ahead. At least to my eyes. Plus, having one figure that can "do it all" is of better value to me and I end up saving money in the long run. Genesis isn't perfect, no figure is, but what imperfections there are, are barely noticable.
I may use BF2 more and more as time goes on, but Genesis will always be my "go to" and "main" figure. It's more versatile for my needs.
Thread: G2F... do you use her much? | Forum: DAZ|Studio
I will never use BF2 as my primary figure and rarely use her. I use GenX to transfer BF2 morphs over to Genesis so I can use the 6th generation with Genesis. I can transfer the UV's too so I can use V6, Gia, etc, skins on Genesis.
Genesis all the way for me.
Thread: Need help, looking for a mini skirt for Genesis | Forum: DAZ|Studio
Thank you! That worked! So I was simply putting them in the wrong area. Facepalm
Thanks for the help! :)
Genesis Mini Skirt and Crop Top, I "think" it's on page 7. Then I tried Genesis 1940's dresses on Page 2, then I tried Genesis Skirts on page 11. I put them in Studio/My Library like the ReadMe says and I've talked with Wilmap already and she's just as puzzled as I am.
If you could provide a sceenshot of where you put them, that would be great. I don't know if that would help but might as well.
Already have, none of those will work for me and I've tried 3 different outfits. Don't know what I'm doing wrong since I am putting the files exactly where the ReadMe says to put them. I keep getting a "Missing Files" error or Error Opening File. :(
And yes I have made sure the files are there by going there manually. The files aren't missing, so I don't know why Daz Studio thinks they are. I've even tried redownloading those files.
Thread: Supersuit Help from Rand | Forum: DAZ|Studio
Thanks, Jestmart. :)
Hi Randy. Back when the Supersuit was showing in the Members only forum you showed a number of "well known" Super-Hero textures you made (i.e. Superman, Batman, etc). You said you'd release them once the suit was released. Did you ever do that? If not, are you making any plans to?
Second of all, I do have a question, Randall. The Basic Supersuit, not the main one, it's UV's are messed up. Torso and back share part of the same UV's which makes it impossible to do our textures. Is it possible for you to do some kind of fix?
Thread: Question about SAV Electra | Forum: DAZ|Studio
And the face isn't 100% accurate. But that's ok. It's close enough. Thank you very much guys, I appreciate the help. :)
Thread: A message and a request from flashback. | Forum: DAZ|Studio
Quote - flashback37: I think you will need to open a support ticket, though if it's an annual membership more than a month old I'm not sure a cash refund will be an option. Christian22179: In theory changing browsers shouldn't do anything that clearing the cache and cookies doesn't - and it really shouldn't be needed in any event. But, thoery aside, I'm glad it worked.
Thanks, I'm glad it worked too. But, I don't know why, clearing my cashe and cookies didn't help at all. I still had the same problems. Still do if I use IE 9. As as Flashback said, I'm fine whenever I go anywhere else in IE 9. Not so on the DAZ website.
Very puzzling.
Thread: Can someone please help me find a morph? | Forum: Poser - OFFICIAL
Thanks, Lully. Those are close but not them.
ICandy: Thank you for your determination! That helps a lot! :D
