2 threads found!
Christolking | 3 | 271 | ||
Christolking | 7 | 563 |
4 comments found!
Is the spline break enacted with the small symbols at the lower left of the graph? I’ve tried that but it hasn’t worked. Maybe time to RTFM.
Thread: Library window missing in Poser 11.3.818 | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thanks an0malaus, I found the preference files. Of course there is both a Poser 11 and a Poser 11 Pro folder now and I have to figure how much I want to mess what around. Since in the past my Runtime folder was outside the Content folder I find I have to make copies of stuff and drop them in the new runtime folder. I don't have a good idea of where the program is 'looking' or where files should be for optimum use. Since Poser 'shifted gears' with different characters and builds, each character has a slightly different set of 'handles'. (And sometimes a hair file is in the hair library and sometimes the figure library. Sometimes hair is an object and sometimes a figure. Sometimes it automatically sees the head as its parent and sometimes it doesn't. Sometimes a breast is part of the chest, sometimes the collarbone, and sometimes has its own category. Well, I'll ease off, but I hope there is a developer or three at Bondware assigned to rationalizing the whole library.
Take care, Chris
an0malaus, Thanks, refreshing the Libraries window with the virtually invisible icon in the bottom right corner did populate the window. However, almost all the legacy figures are now missing from the menus. And I notice that if I drag a legacy figure file to the window or open it from where it is filed i get the La Femme figure instead. Is this the new company policy? Trouble is, the La Femme figure has fewer features and morphs than some of the legacy figures.
To answer your other question: users/shared/Library/Application Support/Poser/11has only 3 files: Poser.dta, PoserActivation.dta, and PoserReg.dta
BTW: The app is UI buggy in ways I would like to share at some point, but I don't want to do a lot of fussing when you have helped me out. Two small things to look at: Couldn't the default for the editing window be to open with the Select arrow button rather than the Translate/Pull button? (I often end up dragging a figure when I am just trying to select a body part.)
The arrow for changing body parts etc. at the top of the parameter dials window will default to the dragging hand and accidentally pop the window loose.
Really appreciate the help. Chris
Thanks an0malaus,
I'm running OS 10.14.6. there is nothing in the users/shared folder because I directed all Poser 11 stuff to go into my Applications/Poser 11 folder. That has worked fine in the past although the app is always hunting for missing files for legacy figures like Pauline or Roxie. Screen shot attached.
Thread: NOT using sine curves in animation (graphs) | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
