9 threads found!
CodeTwister | 5 | 310 | ||
CodeTwister | 3 | 112 | ||
CodeTwister | 22 | 969 | ||
CodeTwister | 7 | 437 | ||
CodeTwister | 35 | 882 | ||
CodeTwister | 1 | 18 | ||
CodeTwister | 0 | 8 |
(none)
CodeTwister | 3 | 18 | ||
CodeTwister | 7 | 55 |
11 comments found!
Hello, I am here! The problem is that I am very very busy these days. I have the Poser5 box on my desk from a couple of months and I have non found the time to install it yet. Yes, with the release of Poser5 I have suspended the develop of The Tailor. The question was: will be The Tailor still useful? Or Poser5 will make of it an obsolete and useless application? Thanking those who have e-mailed me their opinions, I have now understood that The Tailor can keep, in the future, his little place near the big Poser. So, in the first months of the next year I will reorganize my time and will start an upgrade of the program. Bye, CodeTwister
Thread: The Tailor 1.1 update for free at DAZ3D | Forum: Poser - OFFICIAL
Please read this:
http://www.renderosity.com/messages.ez?ForumID=12413&Form.ShowMessage=734829
Bye,
CodeTwister
Thread: The Tailor 1.03 | Forum: Poser - OFFICIAL
The version 1.03 is in the store. Make sure to refresh the temporary internet files of the browser or the cache if you are behind a proxi server.
to NW316, I do not own Stephanie so I cannot tell much about this. If the mesh of Stephanie are near to the mesh of Vicki as a dress is, then the transfer is possible.
Thread: The Tailor - Morphs license agreement | Forum: Poser - OFFICIAL
Thread: "The Tailor" in the marketplace sounds almost too good to be true, is it? | Forum: Poser - OFFICIAL
Ooops...
it is Saturday, I have promise to my family a little trip this weekend. So please wait my other replyes until Monday.
My wife is already out of the door and she is calling me...
I whish you a good weekend
bye bye ciao
CodeTwister
Thread: Does Codetwisters "Tailor" product work on Billy-T and other 3rd party clothes? | Forum: Poser - OFFICIAL
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=594481
See my reply in http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=594481 CodeTwisterThread: "The Tailor" in the marketplace sounds almost too good to be true, is it? | Forum: Poser - OFFICIAL
Attached Link: http://www.codetwister.com
Hi, sorry for the late of my reply. Yes! There is a different time zone problem, I live in Italy. To the problems now. As you know a model is composed by many files. The most important are the geometries (*.obj) of the meshes and the Cr2 files that describe how the geometries are used. The Tailor start the loading of a model with the Cr2 file, search any occurence of the geometrie files and load every obj file separatly. The geometries are linked to the Cr2 through line like: figureResFile:Runtime:Geometries:P4NudeWoman:P4NudeWom.obj or objFileGeom 0 0 Runtime:Geometries:hair:femaleHair106.objAs you can see the files are indicated in mac file format and the root is not the real root of the path but the folder Runtime that, in the reality, is placed under the folder of the Poser installation.
The program must convert this pseudo path in the real path to find the files. To do this it searches in the registry information on where the poser is installed. If it failed in its research the files cannot be loaded because of the wrong path, so the program is unabled to show the mesh. Also... the morphs are linked to the obj through the specifications of the groups that must be the same in the Cr2 and in Obj... so no morphs are showed in the tree. The Tailor in its juvenile state lack to inform the user of this situation.
Morph and models are not showed
The cure:
In registry in HKEY_CLASSES_ROOT
in folder Poser3File/DefaultIcon should be the string:
(Default) C:POSER4POSER.EXE,1
that inform the system where must get the icons of the Posers files
Edit the string and set the exact path. The string must finish with ",1" (comma number one). See the attached picture.
I think to do an automate procedure to do this, next week, to help everyone that not has feeling with the registry.
For other problems with Cr2
The Tailor is tested with all models and clothes in my possess and it works perfectly, but the data structure of the Cr2 files is a nightmare so it is possible that some models or clothes does not loaded correctly. Do not worry with your help I am disponible to improve the program to avoid this problems or individuate what kind of anomalies are present in your Cr2.
CodeTwister
Thread: How do I mirror body parts on Vicky ?? | Forum: Poser - OFFICIAL
I have made some tests with right and left collars and all works fine. If you want, you can send me the file of the right collar morph, so I can verify if there is something wrong in the code. My email is info@codetwister.com. Usually the mesh exported from a 3D CAD contains the list of the vertices and the list of the faces of the mesh. The file generated with Morph Master is smaller because it contains only the list of the vertices. This because Poser ignores the faces when it imports a morph target. CodeTwister
Attached Link: http://www.codetwister.com/Patches/MrMst111a.zip
Oops... I have forgotten that sometime ago in the develop of the program I have disabled the mirror of the morphs. Ok! download this patch http://www.codetwister.com/Patches/MrMst111a.zip Substitute the file MrMst.exe In the step 8 set the check box Mirror Morphs Have fun CodeTwisterThread: How do I mirror body parts on Vicky ?? | Forum: Poser - OFFICIAL
Try Morph Master With Morph Master you can: 1) Import blMilWom.obj 2) From the menu of the morphs of the right collar import the morph that you have created. 3) Click on menu "Stack/Modify geometries to create a morph target" 4) From the tree view click on the menu "Select group" of the right collar group 5) From the tree view click on the menu "Use morph target" of the morph that you have imported 6) Set the value of the morph to 1 7) Click on "Mirror selection" button from the tools "Modifiers" 8) Choose the radio button Right to left 9) From the menu Stack click on "Goal:Create Morph Target" and clear the stack. Two morph targets wil be created one for the right and one for the left collar 10) With menu "Export Morph Target" of the morph of the left collar just created you can get the Morph file to use in Poser You can find Morph Master in Free stuff/Utilities or in my site http://www.codetwister.com/ Bye CodeTwisterThread: Morph Master 1.01 | Forum: Poser - OFFICIAL
Morph Master 1.01 is posted in Free Stuff/Utilities but it can be downloaded also from my site http://www.codetwister.com/This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Thread: Any more updates for Tailor? | Forum: Poser - OFFICIAL
