2 threads found!
Posted Mar 15, 2004 at 11:35 pm | Forum: Poser - OFFICIAL |
DBM | 1 | 80 | |
Posted Apr 26, 2002 at 10:59 am | Forum: Poser Technical |
DBM | 1 | 87 |
2 comments found!
This is my MO-72 Project, a Sphere (72 equatorial divisions by 72 circumpolar divisions) that can change into ALL of the shapes shown here (and then some!). The large spheres on the right show some of the surface polygon groups, while the larger renders in the middle showcase some of the fancier morphs.
NOTE - I had to fake things a bit with the Torus, losing a level of polygons around each of the poles in the conversion - they create a 'disk' that blocks the hole, so I made them 'transparent' for the render. This means that the torus is 72 divisions around the outside rim, but only 34 around the actual thickness of the torus's tube.
Thread: Which is more satisfying for a modeler? | Forum: 3D Modeling
Especially when it's something 'unusual', like turning a cylinder into a bathtub (see picture).
Note - Model created in Poser4 using 'morphs', separate props were then created and UV mapped with UV mapper. Custom Texture, Bump and Transparency maps by myself.
Image rendered in Poser 4, no postwork other than image cropping and format conversion.
