We couldn't find any threads matching the specified search criteria.
11 comments found!
Thread: LIBRARY IS TOTALLY BROKEN IN POSER !! | Forum: Poser - OFFICIAL
Jules53757 posted at 2:35PM Mon, 28 March 2016 - #4246132
There are two possible solutions that both worked for me:
Open IE, go to Internet Options, Advanced and reset the IE settings, this braught my library to work. The other solution is, you go to :
Your installation Path/Poser 11/Runtime/ui/Flex/LSMGUI/bin-release/ and open the LSMGUI.html with the IE, you should have now the library in the IE window and you can switch between Poser and the library with Alt + Tab.
I tried this and was pleasantly surprised when I saw that it loaded the old flash style library inside the internet explorer, no indexing or anything happening, now the question is, how can I make poser 11 pro load THAT library style inside poser instead of the new one? can it be done or do I need to wait for a new SR?
Thread: Render DAZ Genesis 3 in Poser!!!!!! Now you can-FREE! | Forum: Poser - OFFICIAL
Is there any way to turn off the bending limits in Poser all at once like it is done in DS? I tried with a text editor looking for all "forcelimits 1" and changing them to "0" and it does what it says but I get some weird results, I guess not all limits should be removed.
Thread: Latest WIN 10 update (KB3132372) prevents poser 10 from working | Forum: Poser - OFFICIAL
After you uninstall it this tool from microsoft can help you stop unwanted updates for Win 10:
https://support.microsoft.com/en-us/kb/3073930
Thread: Poser 11/Poser 11 Pro: Bug Reports | Forum: Poser - OFFICIAL
I used a text editor to change all the "forcelimits 1" to "forcelimits 0" inside a figure .cr2 that I imported from Daz Studio and I can confirm that it doesnt work correctly in Poser 11 pro, especially the controls that involve moving more than one body part at the same time like the "Neck-Head Bend" control, Poser Pro 2014 ignores the limits with force set to 0 but Poser 11 keeps obeying the upper and lower limit and the "Force limits" checkbox in the dial settings is greyed out.
Thread: Win7 vs Win8 | Forum: Poser - OFFICIAL
Thread: Possible Poser 2012 Pro Bugs here so they are seen. | Forum: Poser - OFFICIAL
Actually I've seen the screen issue too, but I notice that only happens, at least in my case, if you have another screen on top or behind PP 2012 then if you change parameter dials or move from Poser's window to another window the preview creen will stop updating, or it will only update where those windows don't overlap with the preview window or sometimes is the other way around where ovelaping is the only section that updates (like the one 2 posts above this), what I do is to keep evrything minimized or closed and leave Poser as the only active window to avoid that screen issue.
I have a Geforce GTX 560 and Windows 7.
The Symmetry for IK enabled limbs doesn't work, either left to right or right to left, for both arms and legs, when IK is on PP 2012 won't do it correctly, it will apply the symmetry to the shoulder and forearm but not the hand, same with the legs, it will copy the thigh and shin symmetry from one leg to the other but not the feet, this however can be solved turning IK off but this is a waste of time at least for me since I like to work on posing with IK turned on at all times, and this started happening since the first SR.
Also the Undo option from the Edit menu will not catch all the changes or it "forgets" all the changes made from time to time.
What gives?
Thread: Subdivision in Poser | Forum: Poser - OFFICIAL
Content Advisory! This message contains profanity, violence
Quote - I've been following the thread about Genesis in Poser, and the idea of implementing subdivision in Poser got my attention. I've been playing a bit with it today, to see what can be done.
Here one of the hands has been subdivided. It makes quite a difference.
Thread: [Q] Ppro 2012 / Nvidia | Forum: Poser - OFFICIAL
I think the latest drivers have a Poser profile included, I'll check when I get back home from work.
Thread: Yay! P8 fixed one longtime irritation | Forum: Poser - OFFICIAL
Yah THAT is fixed, or not? do you see the little hole below that [ x ] button, is the one that gives you the option to dock or float that window, and guess what? it takes the same amount of coordination to click as the previous hole in older versions of Poser ( ºoº)
