We couldn't find any threads matching the specified search criteria.
4 comments found!
This is where I am going off the rails...do I need to transfer my GF1 to GF2 then to GF3?
Thread: Transferring Genesis morphs to G3F | Forum: DAZ|Studio
i have now created a new file, inserted a new GF3 and used the process you describe above to insert my new morph I now import my GF1 model, this is my source, what I want to transfer to the GF3... Using the Transfer Utility...
Continuing.... This then gets the Morph into GF3Object This is my GF1 model I wish to transfer to GF2 To be continued...
I have read your tutorial. But by the time I try to get my morph from a GF1 to a GF3 the model appears emaciated. I then export this to my OBJ file which I name GF3Object.
Next, in a new file, I insert a Genesis 2 Female model. I set my Resolution Level to Base and the SubDivision Level to 0... Import the GF3Object just created... I then use the transfer Morph as described to transfer the Genesis morph to GF3Object. Dial the Genesis Morph as described...then back to zero...
