9 threads found!
Emanaia | 10 | 313 | ||
Emanaia | 7 | 205 | ||
Emanaia | 6 | 18 | ||
Emanaia | 11 | 72 | ||
Emanaia | 14 | 384 | ||
Emanaia | 25 | 505 | ||
Emanaia | 23 | 282 | ||
Emanaia | 16 | 242 | ||
Emanaia | 22 | 231 |
46 comments found!
To answer quickly as I am running out of time, I will definitely have to read more carefully what each of you have said tomorrow. BUT pjz99, you may have something there. IÂ WAS working with V4. Thank you all for trying to help and if you can think of anymore suggestions, just let me know!
Thread: PLEASE HELP! VERY frustrated :( | Forum: Poser - OFFICIAL
Quote - If it is switched on, you want to switch it off.
Nope, didn't work either after I unchecked it. I even restarted the program again after.
Quote - Do you have "Use external binary morph targets" switched on in
Edit ==> General Preferences ==> Misc ?  I think that that has been linked to crashes in Poser 7.
I checked and yes it is marked. :(
Quote - Is this happening with one scene in particular, or when you try to open any existing scene?
It is not any one in particular. I have tried opening 3 different files and all have the same results. I can not figure out why in the world it would start doing that now.....
Thread: Python Script Problems | Forum: Poser - OFFICIAL
ok, so this is going to sound like a REALLY stupid question but where do I find all 3 of the installers? Thanks!
Quote - I'd suggest running the SR1 installer, then the SR2
installer.Â
I appologoze but I am not sure what you are referring to s
Thread: Help please!!! | Forum: Poser - OFFICIAL
Thank you! Yeah I found another similar one that I may invest in called "HyperREAL" which works with V3 as well as Aiko3 I believe. From what I see, the plus of this one is that it comes with textures, make-up options, eye colors and some light settings, whereas the other doesn't. I'm still deciding. :)
Thank you SO much for your advice! I will definitely look into that kit. I also need to look more into the whole lighting thing as well. There is so much more I need to learn about this program :)
Thread: Help with backdrops | Forum: Poser - OFFICIAL
I apologize but I don't understand what either of you said LOL. What I am trying to do is, I have a character in a room and am trying to move her forward in the room and keep the back walls and table where they are. Thanks :)
Thread: Completely clueless! | Forum: Poser - OFFICIAL
That is my problem then. So to clarify, once I download the correct morph packs, then I do what I have been doing and it will findthe correct files? So I guess I will get the morph pack for both V3 and M3.
