3 threads found!
EwanG | 0 | 61 |
(none)
EwanG | 0 | 69 |
(none)
EwanG | 3 | 96 |
5 comments found!
Note that if you do some searching in the freebies section, there are some trees that are available for free that you could pull into any of the 3D progs and then export as an image to be edited in PSD as well.
Thread: I'm a tree junkie and I need a fix =) | Forum: The MarketPlace Wishing Well
Just as an FYI, I was about halfway through putting together a package when I was reminded of the three product limit for vendors that haven't sold $300 of merchandise yet. So I guess it will be a while before I can post this even after I get finished. That said, you probably want to use one of Agent Smith's ideas above.
LadyVictoire - You can always DL the free DAZ Studio package and see if you can open them in that. Since it says they are Poser compatible, this should work for you. You could then render and export them as JPEG files.
As for myself, I'm working to see what I can do to pull some trees and other items out of my high-res shots as a possible package.
Hope this helps,
Ewan
Just wondering if you would be able to use high resolution JPGs of trees and bushes that you could then cut/paste as needed? I've been looking at what to put up next after my cave/cavern backgrounds, and would be happy to put up some foliage if you think it would work for you.
Thread: Multiple Needs for 3D chars/elements - Figure This is the place to Ask | Forum: The MarketPlace Wishing Well
Quote - describe the look you want, cartoon or realistic and I'll see what I can do.
I'll go ahead and email, but are you saying you have the stuff for the characters, the props, and the setting? Or just one of those?
Thanks,
Ewan
