9 threads found!
HassenBenSobar | 3 | 1245 | ||
HassenBenSobar | 1 | 333 | ||
HassenBenSobar | 7 | 143 | ||
HassenBenSobar | 3 | 52 | ||
HassenBenSobar | 7 | 165 | ||
HassenBenSobar | 6 | 213 | ||
HassenBenSobar | 12 | 170 | ||
HassenBenSobar | 5 | 162 | ||
HassenBenSobar | 2 | 98 |
29 comments found!
Many of the products in my wishlist have reverted to full price. Seems to be an issue with the sale?
Thread: Hivewire Horse vs. Daz Horse 2? | Forum: DAZ|Studio
Thread: Dolly shown as unpurchased on product page | Forum: MarketPlace Customers
Im in Rhiannon's store and all of the outfits i've bought are also showing as not purchased. Same with Lilflame's store. Looks like something might not be working correctly.
Thread: What should I charge to design a business card logo? | Forum: Community Center
Ok, that clears some things up. Thanks A_Sunbeam and rajib. The logo design is based on her ideas so it sounds like she would take the copyright. Quite a bit to digest :)
Thanks for the info A_Sunbeam. Let me ask you this, what about ownership rites for the image itself? Would she take control of the image and final logo or does she gain just the rite to use the image? How does that work?
She's actually our pet sitter. So, I didnt really have any intention of charging her much, we may forgo money all together and she might provide X amount of pet sitting visits for use of the logo. A minimum wage scale sounds just right. We should be able to figure something out with that in mind. Should I also consider material costs, purchased models or stuff like that?
Thread: Coupon not working? | Forum: Community Center
Thread: Poser Dyn clothing now in Daz Studio | Forum: DAZ|Studio
I love it, am concerned Optitex will make DAZ block it but until then am having fun I added a smoothing modifier before freezing and after to an obj export reimport for this as it worked better an much faster than converting to prop
Thats great! Any hints or knowledge you could share would be most appreciated.
I have some questions as I am still not having great results with this. Alot of really long conversion and draping times.
Well, unfortunately my most recent attempt with g3f crashed and I lost it all. However, it was turning out pretty good. I used v7 and the camisole and skirt from the vagabond outfit. Bejaymac's suggestion helped with the time issue. As a matter of fact, I took it a little further. Before converting everything to props, I removed the smoothing modifier, turned resolution level to base resolution, and turned View SubD Level to zero. This improved the both the conversion time and draping time for the items. I let the skirt drape for 51 frames and the camisole for 31 frames. The whole process took under an hour to complete, probably around 45-50 minutes. It crashed when I attempted to increase the draping on the camisole from 31 to 51 frames. I suspect that this may have something to do with the fact that I had it colliding with a skirt prop that I deleted and then replaced at one point for some forgotten reason. Well, off to try again!
Bejaymac posted at 7:37AM Wed, 10 February 2016 - #4254229
Check for the smoothing modifier, it's a "cheat" that way to many use on their products, that's what will be slowing you down.
Oh, of course. I should of thought of that before. Ill definitely check that. Thanks Bejaymac! I imagine that any HD morphs might also slow things down.
I tried this yesterday on a variety of daz clothing, everything from v4 clothing all the way up to g3f clothing and had mixed results. The v4 clothing worked the best and I was able to achieve some descent draping. When I tried it on g3f clothing, the performance in daz became so slow that it became impractical for me to wait for the results. I imagine it would drape for g3f clothing as well as v4 clothing but at two minutes plus per frame I just couldnt wait for it to complete. Im assuming that the real strength of this script will be for poser dynamic clothing which is fine for me. I spent a couple hours yesterday looking for dynamic clothing and adding it to my wishlist. I agree with Mythico, if Daz ever adds a good physics model it will be fantastic (if not long overdue). This script is a good start. Im so tired of autofit that even the smallest improvement in dynamic clothing for daz is welcome. I hope that lola69 continues to support dyncreator.
I purchased dyncreator the other day. Ive been running tests on it most of the day today. Ill have to look into the free poser dynamic clothing.
Thread: Dynamic clothing vendors? | Forum: Community Center
SpookieLilOne posted at 12:27PM Tue, 09 February 2016 - #4254103
Here are a couple https://www.renderosity.com/mod/bcs/vendor/Lully
https://www.renderosity.com/mod/bcs/?uid=572568
https://www.renderosity.com/mod/bcs/vendor/kaleya
sexier items
https://www.renderosity.com/mod/bcs/vendor/SynfulMindz
https://www.renderosity.com/mod/bcs/vendor/lilflame
Thanks SpookieLilOne! Ill check those out.
Thread: Why is my wishlist item not in the End of Year Wishlist sale? | Forum: MarketPlace Customers
