3 threads found!
Hergt | 4 | 286 | ||
Hergt | 11 | 253 | ||
Hergt | 7 | 163 |
6 comments found!
I am running Poser 2014 Pro and the figure circle doesn’t appear although the display is set. I reinstalled the program and it still doesn’t appear, anyone have a solution? Thanks
Thread: Error Message In Poser 2014 | Forum: Poser - OFFICIAL
I just installed Reality 4.2 update today and received the message I quoted earlier. Curious the problem exists for cars from National 7. Renders fine in Poser missing doors hoods etc in Reality.
Thread: Moving Poser files to New Computer and 2014 pro | Forum: Poser - OFFICIAL
Thanks for your prompt reply. I want to put content on a separate hard drive because the SSD will only have 500gigs and I have a lot of content. Could I just install Poser 7 and 9 on the other drive and use the + sign? If so is there a better way?
Thank you for your response but I am still confused about what to do. My plan is to copy the runtime folders (purchased content) from Poser 7 and Poser 9 on an external hard drive. Then install PP2014 on the new computer and place it on the C drive which is a SSD. I want to have PP 2014 use the content I copied from the external hard drive on to the D drive on the new computer. I not want to have to unzip and reinstall all my purchased content again. How do I set up the D drive so that PP2014 obtains the content from the D drive. In other words and this may sound stupid but how do you set up content on a drive other than where PP2014 is installed? How does PP2014 know where to look for content?
Thread: Adding content to Poser 9 | Forum: Poser - OFFICIAL
Sorry to trouble you again but I am still having difficulty adding content to my Poser 9 Library that I have downloaded. I haveWindows Vista with SP2. I have now installed Poser 9 not in Programs but on the C drive. I am able to add Poser 7 runtime to my Poser 9 library. Vistas administrator is turned off. Now when I try and place a zip. file and unzip it either under Poser 9 or the download file it does not appear in either most times. Inked 8 works this way but will only appear in the Poser 9 library but not in the download library part. Other zip. files don't appear at all. When I used Poser 7 is simply downloaded the zip file under either Pozer 7 or its download file I unzipped it and the content appeared in my library. Everything I try and place in the Poser 9 download file does not appear. So with out taxing your patience what am I doing wrong.
Thread: Helping Poser Newbies | Forum: Poser - OFFICIAL
