24 threads found!
HopsAndBarley | 2 | 128 | ||
HopsAndBarley | 8 | 96 | ||
HopsAndBarley | 12 | 185 | ||
HopsAndBarley | 6 | 45 | ||
HopsAndBarley | 23 | 248 | ||
HopsAndBarley | 2 | 29 | ||
HopsAndBarley | 3 | 29 | ||
HopsAndBarley | 4 | 49 | ||
HopsAndBarley | 7 | 48 | ||
HopsAndBarley | 14 | 177 | ||
HopsAndBarley | 6 | 119 | ||
HopsAndBarley | 7 | 168 | ||
HopsAndBarley | 8 | 58 | ||
HopsAndBarley | 3 | 127 | ||
HopsAndBarley | 7 | 75 |
53 comments found!
Thread: simple shadow question | Forum: Carrara
Thread: Robots, Renders, Lights.....oh my | Forum: Carrara
Thread: So... worth buying into? | Forum: Carrara
HOw aboutmoving from Carrara 4 to 5, is it worth the upgrade? Are there any functionalities that were previously only available through plug-ins that are now part of C5?
H&B
Message edited on: 12/08/2005 06:01
Thanks everyone. I've taken out all the objects that werent within the production frame. That should help. I'm still trying to solve that leaking light problem in the back corner though. I made sure cast shadows was checked, changed the floor from a plane to a solid form and raised it a smidge to make sure no space is left between floor and walls.....but I still have light leaking in. As a test I removed the light behind that wall, and the leakage did in fact vanish. So it is caused by that one spolight. I'll keep working on it and run some more tests, try the GI again, perhaps on different settings. I'll let you know how it works out. Thanks, H&B
PS. About that light in the back corner. It doesnt seem to be from the spot that is coming in through the open door. There are 2 lights in the hall. If i remove the one placed near the door, that splotch of light is still there. The second light is place on the other side of the door, kind of (but not quite)level with the back wall.
Thread: Robots playing cards | Forum: Carrara
Cheers,
H&B
I did model my Ipod a while back, maybe I could mskr one those ipod speaker attachements gizmos and put the whole thing on the table. I like the idea of contrasting the hi-tech (well, retro high-tech) robots with the non-tech surroundings. When I first starting playing around with Carrara I modeled an ornate foozball table and room, If I get the time I want to try and put in these robot players around the table. So much carraring to do....so little time. ;o) H&B
One more little detail. I like how you can just make out the bottom of wall that is behind the glass door, a little distorted and colored by the glass in the door. I could probably try and punch it up just a little more. :o)
Cheers,
H&B
Thread: another easy question for the pros.. | Forum: Carrara
Thanks. That did the trick. I did the same thing for relfection and others. It makes all the difference. Thanks again. H&B
Maybe one of the mosquitos could be crawling across the lens of the unseen camera that takes the "picture" of the scene? hmmm.. you know this could be a never-ending picture. There will always be something to add or vary....;o) Cheers
Thread: Chrome texture help (in C5) | Forum: Carrara
