95 threads found!
ItWasNotAvailable | 2 | 132 | ||
ItWasNotAvailable | 11 | 392 | ||
ItWasNotAvailable | 2 | 258 | ||
ItWasNotAvailable | 4 | 656 | ||
ItWasNotAvailable | 3 | 68 | ||
ItWasNotAvailable | 3 | 181 | ||
ItWasNotAvailable | 5 | 251 | ||
ItWasNotAvailable | 1 | 60 | ||
ItWasNotAvailable | 7 | 251 | ||
ItWasNotAvailable | 2 | 165 | ||
ItWasNotAvailable | 3 | 60 | ||
ItWasNotAvailable | 3 | 155 | ||
ItWasNotAvailable | 1 | 117 | ||
ItWasNotAvailable | 2 | 83 | ||
ItWasNotAvailable | 1 | 195 |
157 comments found!
Thread: One newly uploaded (not yet released) freebie needs replacing... | Forum: Community Center
3Dpixi posted at 12:23PM Sat, 17 April 2021 - #4417127
Checked for you and I see 2 DS & 2 Poser products by you in pending
If you can send me a screenshot of a product page by you I am able to check the edit and remove button for you as well :)
The one on the right is the one I am desperately trying to delete and get the message above. This sadly means that I cannot edit anything at the moment. :-( Thanks for looking into it.
3Dpixi posted at 7:55AM Sat, 17 April 2021 - #4417082
Thank you for reporting this LevKornowska .. much appreciated
I will forward it to the team to see where the fix is needed to get it solved
Thanks. I can see the Poser stuff now but still cannot edit or remove anything. I am also wondering whether you guys can actually see the freebies in your queue somehow?? Fingers crossed.
Hi Miss B :-) I have not yet released a Poser version of the stand but the lantern from the set is in the 2 lantern one already. I will look into the Poser version of the stand ASAP.
Thread: In search of a Vendor | Forum: Community Center
You're welcome! I got some of her goodies too and knew instantly who she was referring too. I think she is Canadian but I haven't seen her around for ages (sadly).
Thread: Since name change I have a few issues | Forum: MarketPlace Customers
Thread: Name change | Forum: MarketPlace Customers
Thread: Joanna - StudioArtVartanian....Please Read | Forum: Community Center
Thread: Render DAZ Genesis 3 in Poser!!!!!! Now you can-FREE! | Forum: Poser - OFFICIAL
I see, lol....Great render...tried her afterwards in 2014, couldn't apply any textures. Have not experimented in 11 yet...
anyone tried it with G3M...I end up with toon outline there all the time. Had the same issue with G3F but eventually was OK....just wonder...anyone?
Thread: Memorial for Renderosity Member Gavangar | Forum: Community Center
Sad news indeed and you will be sorely missed....Get home safe and thank you for everything!
Thread: Latest WIN 10 update (KB3132372) prevents poser 10 from working | Forum: Poser - OFFICIAL
OK, sorry it didn't work out and I sure hope you can find a solution for the problem...Let me know if you crack it as I would be interested :-)
Yes Poser 2014 works again after the latest patch and so do other software which were affected (incredimail for one). I did not reinstall the KB3132327 but only the KB3133434 update. Poser Pro 11 was never affected by this update and thus the troubles that you, kruse, are having must come from somewhere else. Maybe you should install it unto a different drive or location and then launch it from within that directory. Run the Poser exe directly from the directory and not from a thumbnail once installed. Also make sure you install the latest version as there has been an update since release. I know it sounds all a bit lousy but maybe worth a try. I also vaguely remember having had issues with an update concerning the preferredstate.pz3 which prevented it from launching but I don't want to give you false information. Did you set a preferred state or are you always launching with Andy? When you uninstall Poser, it never goes completely off your system and those remnants could cause issues, especially if on launch it calls up old memory and can't find what it is looking for. When you re-install I suggest overwriting your preferences when applying SR1.
Thread: Updating from previous versions | Forum: Poser - OFFICIAL
