1 threads found!
Posted Mar 20, 2007 at 2:06 pm | Forum: Poser - OFFICIAL |
KataKita | 6 | 271 |
3 comments found!
Quote - Hello,
I don't know if this will help but I have found that many of the morphs that appear under the "Body"Â heading for clothing items often do not work when the dials are moved. Instead you have to go to the individual body parts and apply them there. For example moving the Amazon full body morph under "Body" may have no effect, but will have an effect if the Amazon partial body dials are turned under "Chest, abdomen", etc....
I tried a variation on this -- selecting all of the parts of the figure below the "root" one and then looking at the properties. What I found was odd, but ought to get me where I want to go.
Specifically, at the root level the V4 body-related morphs are in a folder called "PBM" with the names one would expect, but all of the constituent parts have the V4-related morphs with the "PBM" prefix (so, "PBMAmazon", for example). When I manually conveyed the different morphs I applied to the original figure's various body parts to these equivalents, the jeans snapped right into place.
Your suggestion was, therefore, what did it, and I am grateful :) .
Thread: V4 RealJeans (perahps general clothing...?) question | Forum: Poser - OFFICIAL
Quote - Use the V4 clothing magnets on the jeans, should fit ok then! That's what they're for!
I did try that, but it didn't appear to help. Perhaps, once magnetized, they would respond to new changes to the underlying figure, but they didn't cause the jeans to adjust to what was there already.
Quote - If you see Inj/Rem files related to the jeans then try to inject them (i.e. select the jeans and double click the appropriate inj file) and then look for and adjust the appropriate morph dial on the jeans.
I'm afraid I did, but the existing sliders didn't do anything after that either, nor did new ones appear -- I take it, however, that what you suggest would normally do something along the lines of what I'm looking for? If so that I can take some comfort in that this is apparently an issue with this product in particular.
