51 threads found!
Kerrwolf | 5 | 31 | ||
Kerrwolf | 2 | 13 | ||
Kerrwolf | 6 | 36 | ||
Kerrwolf | 5 | 32 | ||
Kerrwolf | 1 | 13 | ||
Kerrwolf | 3 | 26 | ||
Kerrwolf | 0 | 8 |
(none)
Kerrwolf | 8 | 43 | ||
Kerrwolf | 0 | 8 |
(none)
Kerrwolf | 2 | 20 | ||
Kerrwolf | 0 | 9 |
(none)
Kerrwolf | 2 | 29 | ||
Kerrwolf | 6 | 40 | ||
Kerrwolf | 1 | 13 |
25 comments found!
Thread: Ripple Effect Online Halloween Contest | Forum: Poser - OFFICIAL
Thread: Ripple Effect Halloween Contest | Forum: Poser - OFFICIAL
Thread: Ripple effect Online Halloween Contest | Forum: Poser - OFFICIAL
Attached Link: http://www.ripple-effect-online.com/Halloween2001.htm
I have removed the multiple layers from the contest page that was causing problems. I apologize for any inconvenience or frustration.Thread: flash export on poser pro pack | Forum: Poser - OFFICIAL
I'm not sure about the SR2 problem, but with the Flash export, you have to decrease to # of frames per second in order to increase the number of colors. Try changing the frame rate to 12fps and use 16 colors. These settings usually work well for Flash animations. Kerrwolf
Thread: CodeTwister's MORPH MASTER 1.0 | Forum: Poser - OFFICIAL
I have been unable to run this program. Whenever I try to start it, the program closes and I get the following error message: Exception EOpenGLError in Module MRMST.EXE at 0007AE19. Need at least OpenGL version 1.1 I have OpenGL which functions properly in Vue d'Esprit 4. Can anyone offer any solutions? Thanks in advance.
Thread: Comming soon... | Forum: Poser - OFFICIAL
Attached Link: http://www.rbtwhiz.com/reviews/DP3DTW.html
Spike, Rob Whisenant wrote a review about Deep Paint that said the program took it upon itself to triangulate the mesh he was working with instead of leaving it as quads. This would significantly increase the file size of your model. I've posted the link to his review. KerrwolfThread: VUE 4 Shipping Mid-June | Forum: Vue
Thread: Thats so funny! | Forum: Photography
Thread: Posergamers finally finds a new home! | Forum: Poser - OFFICIAL
Thread: Halloween Contest | Forum: Poser - OFFICIAL
Thanks for pointing out the way Byte Me OK. BTW new images are up, including yours Marque.
Thread: New Images Up In Halloween Contest | Forum: Poser - OFFICIAL
Using Vue would be fine as well. As long as there is Poser work in it. Photoshop is okay too. I should have been clearer. The only required program is Poser for the character modelling. Other then that combine/use whatever other programs you'd like. And, there is no limit on # of entries. So, eneter as often as you'd like.
Thread: Image mount | Forum: Poser - OFFICIAL
Thanks Lobo. I've had it for a while now and have been using it on my desktop with some of my photos. It just occurred to me to offer it to others.
Thread: Cyberdog | Forum: Poser - OFFICIAL
