19 threads found!
KiDAcE | 5 | 153 | ||
KiDAcE | 4 | 88 | ||
KiDAcE | 1 | 294 |
2003 Jan 14 10:41 AM
KiDAcE | 2 | 113 | ||
KiDAcE | 4 | 294 | ||
KiDAcE | 23 | 558 | ||
KiDAcE | 3 | 338 | ||
KiDAcE | 10 | 293 | ||
KiDAcE | 1 | 65 | ||
KiDAcE | 2 | 320 | ||
KiDAcE | 15 | 515 | ||
KiDAcE | 1 | 17 | ||
KiDAcE | 1 | 19 | ||
KiDAcE | 3 | 22 | ||
KiDAcE | 11 | 65 |
46 comments found!
To give you some insight Monica on a 32bit app running on a 64bit system; it'll run but will not take full advantage of the multi-threading capabilities of the processor. UF5 runs smoothly on mine but things like sterling and tierazon tend to crash and those were 2 of my favorites to run.
Thread: 64 bit architecture | Forum: Fractals
Thanks. I remember xenodream from about 5 years ago. Never tried it though IÂ have downloaded it since the theft. I'll have to try that one for a spin
Thread: Image Genre Addition | Forum: Community Center
Maybe because they lacked the mentioned subject. I thought however that Pin-ups were female solos with limited props focusing mainly on the female (like what you would see on the side of a war plane) whereas glamour is something that focuses on an environment. Subtle differences but different. Example 1 of glamour: 1 Example 2 of glamour 2 Example 1 of pin-up 1 Example 2 of Pin-up 2
Thread: Fractals & microwave ovens | Forum: Fractals
That's damn hilarious! I see some peoplle trying to get better effects than you and leaving it in too long and the nuker over-nukes and burns the house down. There ain't no safe way you could go close to a running on fire microwave...you get nuked too! I like the lightning bolts too. I once put in a frozen Skor candy bar not knowing there was mylar (flexible metal) in the wrapper and watched in horror as I thought I was done for. I thought the bolts would zap me if I tried to turn it off.
Thread: Fractal 3D ? | Forum: Fractals
Thread: Thumbnail size | Forum: Fractals
sophielerlei nailed it however there is a easy to use program from ulead.com called smart saver pro that does a lot more than optimize thumbnails. They also have paint programs and 3D programs and am quite suprised that almost nobody I know of seems to use them....they are professional grade producers and their paint prog Photo Impact also supports PS plugins but they have awesome plugins built into PhotoImpact7 too. Not to mention plugs for PS as well. Great place to shop!
Thread: NOTICE: If you use our free models please read... | Forum: Poser - OFFICIAL
There is another script you could use in conjunction.....it's not needed. Just to clear that up.
There are scripts for this purpose you know. Anti-leeching scripts. Some run cgi-bin others *.php, *.asp, and vbscript. I don't think I've found one in Java or javascript. It prevents links from being followed unless the click originated from with set parameters (your site.com) If coming from theirsite.com it wouldn't let them access it. There is another script to use in cojunction with that script.
Thread: Poser Python Wish List | Forum: Poser Python Scripting
A script that can conform clothes to the correct shape and size of the poser figure? You know...a script to make Vic's clothes fit one of her morphed sisters. I guess something along the line of "auto sizing interchangable clothes" so Vic can wear P4 and P4 can wear Vic's etc. Is that possible in Poser?
Thread: I would like to know your opinion and suggestions about my pack in progress. | Forum: MarketPlace Showcase
Maybe it would be different if you did the tags yourself. I think most taggers wouldn't mind seeing their tags in other people's works as it would be to their success that they even tagged your image. To capitolize off it is another thing. I'd be a little mad to know that someone like yourself made money off my tag and wasn't letting me in on the cut....as "it is my tag" so to speak. They did the work and you take a picture of it to make money....you're dealing with gangsters wanting money just like you. I think it should be free. I live in L.A. I can get pictures of tags, bombs, and peaces anywhere I want for free. Try tagging walls yourself then you can make the money. Until then...I guess don't get caught slippin' in enemy territory.
Thread: Artist's Manifesto: | Forum: Poser - OFFICIAL
Thread: Making bump maps with colored images....how? | Forum: Poser - OFFICIAL
So for all intents and purposes: Black = Holes White = Mountains To get the bumpmap I greyscale the texture and then to get correct shadowing I would then invert the green channel? Well sounds good. Sorry for the confusion with this I was a bit lost. Keep thinking blackholes and white mountains....wonder if it's the same in Poser5...the glitchiness/quirkiness. Thanks all for the feedback
Thread: A 24-HOUR CONTEST | Forum: Poser - OFFICIAL
