3 threads found!
Kinder-1 | 14 | 193 | ||
Kinder-1 | 3 | 71 | ||
Kinder-1 | 10 | 135 |
16 comments found!
Hi Andy, I've installed the SR3.2 update but this hasn't resolved the problem. There is still no unhide option when I click on the arrow by the parameter dial. Also when I run the script I still just get a pop up list which does not do anything. However I've just bought the ultimate teenager set from Renderosity and this is working well so I now find I do not really need Lyrra's product any more. Thanks for your efforts and I'm happy that you've prompted me to install the update so my Poser Pro is working better and this has at least achieved something.
Thread: Problem with Unhide Parameter Dial Script | Forum: New Poser Users Help
Hi Andy - sorry to be a pain. I've found the updates (thank you). There seems to be 2 for my version of poser - SR3.1 and SR3.2 - Do I need to install both or does 3.2 already include 3.1
Thanks
Hi Andy, Sorry for delay - I've been on holiday. I did update my Poser Pro 2012 but my computer died last year and when I installed PP 2012 from my disk onto my new computer I have never got round to installing any updates. Should I do this? If so how do I do it as I've forgotten.
thanks John
Hi Andy Basically I just want to be able to use Lyrra's M4 Child Dial in Poser Pro 2012 - so any solution is welcome.
Thanks donnena for your help on this. The M4 Child Dial read me said that you needed to expand the parameter dial options to reveal the hidden values by clicking on the white arrow or right clicking before loading the product. Otherwise it wouldn't work. When I did this the unhide option was absent. I subsequently googled the issue and found a Poser forum on Daz where the same problem had been discussed. Apparently some versions of Poser do have the unhide option (including some old ones) but some don't and that includes Pro 2012. This Daz forum suggested downloading the script and gave links which is what I did. As I say when I run the script I get the two columns as shown in the freebie description but I'm not sure what to do next. The parameter dials do not show the hidden values.
Sorry I realise that I have described the problem inaccurately. When I run the script get a pop up of two columns of dials - one says hide the other show. The actual parameter dial on the figure is not altered. It is when I try to inject the product from Lyrra that Poser crashes.
Thread: Light puzzle | Forum: New Poser Users Help
Thread: M4 Morph Issues | Forum: New Poser Users Help
I did as you suggested and fantastic - everything works. I now have morphs++ as well as CC, Freak, Hiro and ethic faces all working. Plus all my figures load as they should. I can't thank you enough. Thanks sooo much. Your work here is done!!
Thank you for taking the time and trouble to help me on this - I really appreciate it. The characters that are not working/morphing in respect of their bodies are some from Mortem Vetus (Toerag and Lladraks). The heads morph just fine. I have got figures from GhostofMacbeth and Rawart and they look OK without the body morphing. Strangely I have another Mortem Vetus figure (Grobblers) and that is the only one that changes the body shape as it should. Even with this latter however there are no morphs++ in the parameter dials such as I have with V4/A4.
I purchased V4 and her morphs in 2012 and they came in the form of .exe files which I installed into an "unpack" folder and manually installed in my runtime. I purchased M4 and his morphs (++, Creature Creator, Ethnic Faces) in 2014 and by that time Daz was using zip files. I'm now not sure if I "initialized" them as I just extracted them and manually placed in my runtime. Could you advise me on how to initialize if I reload them from scratch. Thanks again.
My M4 issues predate my change of computer. Previously M4 and all morph injections were in the main (and only) runtime so within program files folder. It didn't work then. Since I changed my computer M4 and indeed all library content is on the old imported runtime which sits on my desktop. It doesn't work now either. Interestingly V4 and her all morphs have always worked perfectly and still do.
Thanks hborre. I have turned external binary morph targets off and at least the morphed M4 heads stay morphed when I reopen a saved scene. I have installed SR3.1 but am still having no joy with M4 morphs++ working. Do you think my problem could be solved by updating to Poser Pro 2014?
Thread: Helping Poser Newbies | Forum: Poser - OFFICIAL
Hi all, I'm using Poser Pro 2012 on Win 7 64 bit system. My question is why do I get darker legs and feet (on previews and renders) when V4 is in a sitting pose whilst when standing all skin has the same brightness and contrast. I've tried different SSS mats but no change. I do not think lighting or shadows are the reason as in some poses V4 is holding her legs; and her arms, hands etc are as bright as her body but her legs and feet remain dark. I tend to use lights by Mild Boreal or Sveva with or without AO and backlighting. When I just use V4 in her purple bikini (ie no additional mat applied) there seems to be minimal difference between legs and the rest of her body. Thanks for any advice.
I am making a few tentative steps in Poser Pro 2012 and have Win 7 64 bit. I have read this thread and got great help. I've just downloaded EZSkin and have installed the EZSkin 2.pyc into the Python Scripts menu but when I try to run it (having loaded V4.2) I get a message which says "EZSkin requires build 21462 or later - apparently I have got build 16510. Anyone know what I can do to proceed? Thanks.
Thanks but i've manage to sort it. Now got the textures correct. Thanks for your interesst.
