318 threads found!
Kixum | 28 | 1514 | ||
Kixum | 14 | 654 | ||
Kixum | 13 | 330 | ||
Kixum | 4 | 240 | ||
Kixum | 20 | 1509 | ||
Kixum | 16 | 1499 | ||
Kixum | 27 | 4018 | ||
Kixum | 7 | 422 | ||
Kixum | 15 | 442 | ||
Kixum | 8 | 265 | ||
Kixum | 1 | 104 | ||
Kixum | 3 | 123 | ||
Kixum | 1 | 95 | ||
Kixum | 1 | 33 | ||
Kixum | 2 | 289 |
1,704 comments found!
So, if somebody wanted to "buy" Carrara from Daz for future new development, how much money would they want?
-Kix
Thread: So long, and thanks for all the fish... | Forum: Carrara
Thread: Creating a cell style shader in carrara | Forum: Carrara
On a side note, here's a render using the general cell shader in Carrara. I have found that getting a good result requires rendering the scene with a very large size and then reducing the image to a more practical size afterwards.
-Kix
I think the answer is yes. I don't know about specific geometry but you can specify how toon pro behaves for specific objects. In the attached image, I have turned off the lines for the sphere but left the lines on for the cube. To do this, select your object, select the "Effects" tab, and there should be a toon pro block of options. You can override the toon pro general scene rendering options there and substitute specific rendering options for each object.
-Kix
The render I posted uses toon pro but some of the elements (the canopy) does not. The built in cell shader is not bad but it does require some tweaking to get it to work well.
-Kix
I guess I am a little surprised at this approach. I would try the cell shader native to Carrara first (as suggested). I use toon pro also which I like very much.
-Kix
Thread: New Gallery Upload | Forum: Carrara
I render a lot of space stuff. It's quite repetitive so I don't post in the gallery very often. Been using Carrara for a very long time now (20 years if you include raydream stuff).
-Kix
Thread: Congrats to PhilW – Renderosity's Artist of the Month! | Forum: Carrara
Thread: Roar of the Russian Bear | Forum: Carrara
Thread: The First Tank again | Forum: Carrara
Thread: The First Tank | Forum: Carrara
Thread: Another next project (light sabers) | Forum: Carrara
Ok, the package is uploaded to freestuff.
As soon as it is approved, it will be available! Enjoy.
-Kix
And finally, Palpatine. I must confess that this model is not complete. There are 5 notches that should be along the side that I did not put in because I just didn't want to take the time to figure it out.
So, are these accurate? That's a good question. I have done some research on each one on the internet plus, I have several of the Hasbro higher end light sabers which are excellent references.
In a coupe of days, I will post a file here at Rendo in the Freebie stuff for all of these models (Carrara models only). These models also use some plug-ins in the textures.
-Kix
Thread: Carrara's future (or not) via Daz support | Forum: Carrara
