We couldn't find any threads matching the specified search criteria.
28 comments found!
Rhia and hborre, I would love to see your material settings for the cycles setup at some point!
Thread: Post your Dawn renders here! | Forum: Poser - OFFICIAL
As for the input from the HSV node, I see your suggestion DeecayArt, and I will try that out.
I did not expect to open such a deep technical discussion. But I find it very enlightening to see the chart and the calculations behind the render result.
I suppose I am more of a bumbler, tweaking values and evaluating the rtesult, But I do appreciate the inportance of your underlying arguments.
I'll keep the chart for reference!
Thank you both of you, hborre and DeecayArt!
Hmmmm....
I have followed your advice and reduced the values to:
R-0,8, G 0,4 and B 0,4 with a scale of 0,015 - with the desaturated defuse map linked into the channels (like in my latest post
R--0,48, G0,18 and B 0,11 with a scale of 0,015 - without a texture linked in.
Both results are good and more or less equivalent.
The interesting bit is that the values of R-2, G-1 and B-1 in my original texture are some I got from a previous discussion in the R'osity forum, and I've seen them used in various textures I have come across.
But for Dawn 2, I'll be following your light and go with the lower values. hborre - thank you again!
Thanks for the comments, hborre!
I took out the Fresnel and you're right - makes no difference.
As for the SSS, I placed a light behind her and ramped up the SSS values. This works well now - maybe even a little bit too much.
Notice that I still have the Method set as Burley. When I switched to Walk Fixed, the SSS disappeared... Don't ask. I do not know why.
So here is my tweak of the Dawn 2 materials. I have looked a little to Project Evolution for inspiration. The hair is OOT's Ammu hair for La Femme.
Thread: Dynamic Clothes WIPs for La Femme 2 | Forum: La Femme 2
I think the shirt and skirt works really well. Great idea to do a pre-buttoned and a loose one. My guess is that a top two buttons open version might be really useful.
The set is lovely. The see-thru-ness is undoubtedly part of it. But for the presentation picture a bit more obscurity might be advisable.
Since you have the whole body modelled, I'd suggest that you also do a pantyhose, stopping at the waist.
Thread: LaFemme 2 Render Thread | Forum: La Femme 2
I made this character with the LF2 face morph 3Dream posted yesterday: https://www.renderosity.com/freestuff/items/97076/3dream-omg-face-2-for-lf2.
I have usewd the LF2 base texture together with Tempesta3D's Angel and Senile Santa textures. I have used the Senile Santa for the bump map. The hair is OOT's Daily Bun hair.
Thread: La Femme 2 Freebies | Forum: La Femme 2
