2 threads found!
LilLili | 12 | 1519 | ||
LilLili | 4 | 129 |
8 comments found!
Oh my gosh I feel so dumb. Its because I've been still using 4.10. As soon as I upgraded to 4.12, the issue went away and Iray can now do ~1000 iterations per minute
Thread: Help with Nvidia Iray and GPU usage | Forum: DAZ|Studio
I downloaded and installed CUDA 11.1, but still getting errors :(
2020-09-24 10:24:58.406 Iray INFO - module:category(IRAY:RENDER): 1.1 IRAY rend info : NVIDIA display driver version: 456.43 2020-09-24 10:24:58.406 Iray INFO - module:category(IRAY:RENDER): 1.1 IRAY rend info : Your NVIDIA driver supports CUDA version up to 11.1; iray requires CUDA version 8.0; all is good. 2020-09-24 10:24:58.421 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.1 IRAY rend warn : CUDA device 0 (GeForce RTX 2080 Ti): compute capability 7.5: unsupported by this version of iray, please look for an update with your software provider. 2020-09-24 10:24:58.421 Iray INFO - module:category(IRAY:RENDER): 1.1 IRAY rend info : Using iray plugin version 4.6-beta, build 287000.7672 n, 23 May 2017, nt-x86-64-vc11. 2020-09-24 10:24:58.421 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.1 IRAY rend warn : GPU 1 (GeForce RTX 2080 Ti) with CUDA compute capability 7.5 cannot be used by iray photoreal. 2020-09-24 10:24:58.421 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.1 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
This might be the issue:
2020-09-20 15:48:38.831 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.0 IRAY rend warn : GPU 1 (GeForce RTX 2080 Ti) with CUDA compute capability 7.5 cannot be used by iray photoreal. 2020-09-20 15:48:38.831 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.0 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
So with both CPU and GPU checked, it takes roughly 20 minutes or more to fully render a scene with only Victoria 8, and nothing else. Does that sound normal? It seems really long to me. All my drivers are up to date, and I'm using default render settings, apart from the check boxes for CPU and GPU.
Is it possible to utilize both CPU and GPU? If I select both in settings, Daz only uses my CPU. Is that the bug you mentioned?
Thread: BreatJig Not Working | Forum: MarketPlace Customers
Brittany posted at 2:38PM Wed, 15 April 2020 - #4386324
I was told for use with Genesis 8, you must use the second zip file... lola69_BreastJig2-0_DS_Plugin_240088.zip. The other one does not work with g8. Also, I have email the vendor for you. You should hear back from them soon.
That is the version that I am currently using, and thank you!
