1 threads found!
Posted Mar 01, 2017 at 4:34 am | Forum: Suggestion Box |
Lughir | 2 | 48 |
4 comments found!
This seems like a required element in the site, but you can check addons like Stylist and Userstyles / -scripts to update the site for just you?
Thread: Wishlist Icon on Search Page | Forum: Suggestion Box
Thread: Add Renderosity as store to DazStudio | Forum: Suggestion Box
While I can definitely understand the reluctance in believing Daz would allow it, the source of the documentation seems to show that they do in fact allow it. However, I will indeed get in touch with Daz and check with them what they allow and what they will supply.
And it wouldn't be the first time I find a workaround or can produce a near identical copy of some company's metadata ;)
Thread: A much needed change in the STORE | Forum: Suggestion Box
Perhaps there can be an option to block certain content. Such as a blacklist, which blocks all products with certain tags. That being said, I personally wouldn't use it, and I am unfamiliar with the system that is used to run the marketplace. Perhaps there are options or plugins for that system that allow this.
However, for such an invasive change in the way the site works, I would say that at LEAST 50-60% of the users of this site should wish for this.
@McGrandpa Please do realise that if this is something that will have to be custom coded into the system, this will bring downtime of the site, possible (likely) introduction of bugs and other inconveniences to you, me and other users. I do very much understand your point of view, as I am a devoted DS user, and have absolutely no interest in Poser-only items. However, I see sufficient ways to find what I require. It may be a few more clicks, but that's a minor effort compared to what needs to be done to implement this.
I do not mean to bypass admins or mods, or make suggestions or assumptions that are incorrect. I am just replying from my experience as a senior programmer.
Thread: How to remove webpage headers? | Forum: Suggestion Box
