4 threads found!
Max3DD3 | 5 | 94 | ||
Max3DD3 | 22 | 236 | ||
Max3DD3 | 6 | 174 | ||
Max3DD3 | 5 | 151 |
14 comments found!
Thread: Can i animate my own .3ds model in poser? | Forum: Poser - OFFICIAL
I'm having trouble with speed of edit due to every time i mouse of the object it renders a red wireframe of it which is piss annoying and slows things down - is there a way round this?
Attached Link: http://www.rendiathon.netfirms.com
thats a 7minute render on dual 3ghz xeons. using vue5 with mover would like to upgrade to infinite. that model is using basic textures - meerly a preview! I have 5 node cows but they keep crashing each @ 1.8ghz check website to see!Thread: Poser5 animation will not import into vue5?! | Forum: Vue
It is modeled so that it has seperate joint parts ie there will be no need for bending! that image is HDRI in vue5 where i am hoping to render the animation.
update - cant find it! can you do me a screenie all i have at the bottom is the keyframe/frame bar?!
how do i bring up the setup room? Sounds like a plan! just have to group the relevent opjects together because the differnt parts eg top leg are made of several drawings
Thread: Out of memory error! Vue5Inf. | Forum: Vue
Yes you may have 500GB free but windows may not know that it can use it ususaly you have a pagefile set as a maximum of twice your real ram size check 2nd message to expand.
right click on mycomputer icon> properties> advanced> performance settings> uclick all the pointless windows smoothing functions then go to the advanced tab and hit change under virtual memory - there you can set the amount and where vue can use a page file or any other program for that matter
Thread: Rendering with dual Xeons | Forum: Vue
Well HT you have two bars one is the chip kernal which deals with task alocation and the other bar is your core usage, HT is great for windows makes things load much faster but when it comes to rendering best to turn it off or for endcoding for that matter.
Thread: UV mapping in vue5? | Forum: Vue
well lets say i use UVmapper the program and map a texture to an object such as a decal will when i import the object into vue5 be kept as a decal?
