12 threads found!
MaxxArcher | 16 | 325 | ||
MaxxArcher | 0 | 203 |
(none)
MaxxArcher | 14 | 435 | ||
MaxxArcher | 8 | 282 | ||
MaxxArcher | 4 | 247 | ||
MaxxArcher | 51 | 1272 | |
MaxxArcher | 7 | 162 | ||
MaxxArcher | 4 | 149 | ||
MaxxArcher | 4 | 22 | ||
MaxxArcher | 40 | 248 | ||
MaxxArcher | 13 | 52 | ||
Advisories: nudity
MaxxArcher | 3 | 16 |
221 comments found!
Thread: Troubleshooting Poser 5 | Forum: Poser - OFFICIAL
Try shutting off ansitropic filtering and anti-aliassing, esp. the filtering has posed me a lot of graphical trouble on my PC (not only in Poser). Performance should increase dramatically... Maxx
Thread: Manually editing HUGE CR2 files... | Forum: Poser - OFFICIAL
Thanks for the great additions everyone, I know some of them alright. I'm a Delphi developer so I think I stick to synEdit myself and add my own little tidbits when needed...
Thread: Injecting V3 takes all nite, still no morphs, HELP??? | Forum: Poser - OFFICIAL
Thanks All, I'll give your sugestions a go (still isn't working right after 12 hrs or so). BTW Ratteler, I suggested my girlfriend this injecting thing, but she had a headache, go figure...
Thread: Opinions wanted, does she look like someone else? | Forum: Poser - OFFICIAL
Thread: OT: and off color....but decisions, decisions | Forum: Poser - OFFICIAL
Thread: How to increase amount of memory to POSER??? | Forum: Poser - OFFICIAL
Thread: I feel I got ripped off with Poser5 | Forum: Poser - OFFICIAL
I run P5 SR1 on a 1.3Ghz PC with 128Mb RAM, 40Gb HD with just 1Gb free space on WinME. So far I only have trouble with the obvious lack of memory (as to be expected, not a P5 bug!) and a few (dismissable) userinterface oddities. P5 works great for me (so far...). Im sorry for those people that don
t seem to get P5 in working order, however, did you consider the fact that your OS might be the troublemaker? Both XP and 2000 are know to have 100s of bugs...
Thread: For those having problems with Poser 5... | Forum: Poser - OFFICIAL
P5 runs quite well, just some acceptable userinterface hickups once in a while.... WinME on a HP pavilion 7885 P5 SR1 AMD Athlon 1.3Mhz 128Mb RAM NVidia GeForce2 MX/MX400 32Mb RAM 40Gb HD Windows determines swapfile size...
Thread: I change a morphs "Sensitivity" setting, later its back the old way??? | Forum: Poser - OFFICIAL
Thread: CL Throws up its hands... | Forum: Poser - OFFICIAL
Hi,
On a few occassions with previous PCs I ran into BSOD errors because my BIOS and/or Graphical memory addresses were being shadowed
. Sometimes I ran into conflicts with MMedia drivers, on other ocasions into graphical problems. The use of this shadowing
mostly was to get as much low memory free as possible and to make the memory usage run faster.
In simple terms shadowing
means: make a copy of a range of addresses (BIOS, Graphic pointer etc.), put them somewhere else in memory and tell the PC to make use of those copies instead of the originals.
You can find info on whether your BIOS etc. is being shadowed in your BIOS Setup. When you boot up the PC you have got the option of hitting F1 (on my PC) or another key to enter Setup. Search for shadowing options in the Setup, probably in some Advanced Options. Should you have such options, write down their settings (NEVER forget that!!!). Disable enabled options, save the settings and reboot.
If the PC runs fine, test P5. If P5 runs (hopefully), get back into your BIOS Setup and enable the options you disabled one by one. Each time reboot and test P5. You finally will find the booger harrassing you all this time.
If the PC does NOT run fine, reboot and get back to your BIOS Setup and enable the settings you disabled one by one, reboot and keep doing this step until your PC runs fine again. As a last resort, use the BIOS reset option of the BIOS Setup.
IMPORTANT: when you are totally unfamiliar with BIOS and BIOS Setup, have someone with more knowledge do it for you, we don`t want to mess up your PC, do we?
Hope this helps you further, mail me at maxxarcher@hotmail.com if you need more info.
MaxxArcher
Thread: Need e-mail from Curious Labs for Poser 5 problem report | Forum: Poser - OFFICIAL
Thread: POSER5 UPDATER? | Forum: Poser - OFFICIAL
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=900499
Read my reply in the thread above and you know what to do... MaxxArcherThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
