We couldn't find any threads matching the specified search criteria.
4 comments found!
Quote - I run Photoshop 7 (32bit) and DAZ 32&64 on my 64bit lqptop. I have 2 external 1.5 t-bite drives and i have no problems. os is win7. DAZ will run, but it is all in how you set it up. So, yes! it may be good for you to get intouch with DAZ they are very good at hepling get set up, I have called then a number of times and will do if i need them.
Thanks for the info! ;o)
Thread: DAZ4 Free Download, W7, and existing files | Forum: DAZ|Studio
Hmmm - I've used the older Win installers for DAZ and my Micrografx (a 32-bit graphics program like Photoshop). Absolutely nothing worked to get those 2 programs to run on my 64 bit computer. I had to find an (old) upgraded Micrografx (64 bit) and upgrade my DS3 to DS3A - then upgrade to DS4A.....
I thought about using the external drive... but it wouldv'e ran waaaay toooo sloooow... ;o)
Is your new computer a 64-bit? If so, contact tech support.... see if there's someway you can patch into a 32-bit version of DS with W7 64-bit. (Also, using the computer's installer files from older versions of Windows didn't work.)
Maybe they can help?
Good luck!
One issue may be if your running 32 or 64 bit and then trying to install a Daz program for the opposite bit.
I had that issue. I got this computer W7 64-bit. My DS was a 32 bit and wouldn't work. I had to by the 64 bit DS4 Advanced upgrade.
