We couldn't find any threads matching the specified search criteria.
4 comments found!
Referring to WandW post:Â Â posted at 11:10PM Wed, 06 May 2015
I have the same V 4.2 initialization problem on Poser Pro 2014/Mac OS X 10.8.5
Using the DzCreateExPFiles command should be the solution, but the Mac version of that command always return the message: "No such file or directory". Apparently it doesn't find what it needs in the Contents/MacOS folder.
Anybody has an idea how to fix that ?
Thanks !
Thread: WHERE DID MY LIBRARIES GO? | Forum: Poser Technical
OK. So I understand that when a creator mentions SSS, it means his pose file makes use of that facility.
Effectively, it's obvious now !
What about SSS (SubSurface Scattering) ? Is it a file I must use one way or another, or it is just there for convenience, to be used by any software that supports it ?
Thanks for your help !
When I install a morph in Poser it generally comes to the Library with two files: INJ & REM. What do INJ and REM mean ? How should I use them ? Any clarification will be welcome ...
Thanks !
Thread: Poser FAQ: Want to contribute? | Forum: Poser - OFFICIAL
